2012 Fit making a knocking nosie in the front end
Old Jan 28, 2014 | 12:13 PM
imprtcrbff58's Avatar
Hi guy ,
I'm in trouble i have my car at the dealer today and im at the end of my 60000 warr . I have been having a metal knocking sound in the frontend driver side . Wondering if anyone have had the same problem . My car is a 2012 FIt sport . Please Help Dealer is Blowing me off can't find the problem
Old Jan 28, 2014 | 12:18 PM
Steve244's Avatar
When does it occur?
Old Jan 28, 2014 | 12:20 PM
petawabit's Avatar
Originally Posted by imprtcrbff58
Hi guy ,
better descriptions illicit better responses. we need more information. does it happen under suspension load? certain speeds? consistent with engine speed or throttle application? when turning?does it happen only when your gf's cat is sitting on the passenger side when it's 60 degrees out while you're going up an incline?
Old Jan 28, 2014 | 12:26 PM
shamoo's Avatar
This. Please let us know under what circumstances it's occurring.
Are you able to recreate it at the dealer? If so, there's no reason they will "blow you off". There's obviously something not right and they must repair it under warranty. However, if you can't recreate it, then that's another story.
Have you modified the car in any way? Suspension?
Old Jan 28, 2014 | 09:51 PM
I'm sorry guys for not being more descriptive I was just so pissed off the Off the wa dealership was treating me.it was a knocking sound as you would go forwards and backwards.it would make the sound louder if you would go forward stop then reverse it then break . they found the problem it was a axle bolt that was loose and allowing the actual to move forwards and backwards in spindle I thank you for your replies
Old Jan 29, 2014 | 05:16 PM
D429302's Avatar
where in washington are you? thats weird that an axle nut came loose. have u removed it before? sounds like someone forgot to stake the axle nut!
knightjohannes
Aug 26, 2016 06:32 PM
skinny557
Dec 7, 2012 07:18 AM
lkaglove
Sep 7, 2012 11:19 AM
Grayfox
Jul 10, 2012 07:45 AM
JDMxGE8
Aug 19, 2011 02:39 AM
