Car makes scraping noise when going over bumps
Old Feb 26, 2014 | 04:51 PM
Eamper's Avatar
It might be your oil pan underguard came off loose or your rubber lip under the bumper
Old Jun 4, 2014 | 11:06 AM
camivill's Avatar
so what was it?
What was the reason for the sound?
Old Jun 30, 2015 | 05:30 PM
GinoLicious's Avatar
I have this issue now. Coming from my rear when I go up on an angle to get into a steep parking lot. Sounds like rubber that is rubbing. Not metal. I am lowered on coil overs. But not tucking.
Old Jul 1, 2015 | 03:27 PM
wzlfit's Avatar
Had a similar sound. A cross between a plastic scrape and rubber creaking. Mine came from the back end. I jacked up the back of the car, loosened the top bolt on the rear damper, pushed the bolt down enough to spray a bit of graphite in between the rubber top to the damper & the metal. No more sound. I am lowered but I have plenty of clearance.
Old Jul 1, 2015 | 03:37 PM
That metal plate and the rubber in the back of the trunk eh? I never thought about that. I'm gonna loosen that and spray lithium grease between the metal and rubber. Thanks for the tip. Will also spray under the rubber why not.
Old Jul 10, 2015 | 02:03 PM
ck42's Avatar
Have the same thing here. Noticed it the last few years.
Also noticed that it only happens in the winter.
Seeing others mentioning the same thing has me even more certain now that the noise is the result of something in the suspension (happens going over speed bumps for me) getting noisy when it's cold (enough).
Old Jul 10, 2015 | 02:20 PM
It has to be the suspension. Mine goes away in the rain. I also lowered my Fit on HSD coilovers. And they are a few months old so I dunno.
Old Jul 15, 2015 | 12:11 PM
Mcshine's Avatar
Similar problem
Originally Posted by sneaky_flute
This is kind of a weird issue I've been having for a few weeks. Everything is fine when traveling on flat ground, but once I drive over a speed bump or hit a dip in the road, I hear a scraping/grinding noise. At first I thought it was the splash guard or something hitting the ground, but nothing seems to be out of position.
Does anyone know what this could be?
Your description sounds very similar to mine- I suspect it is the ball joint(s). Mine is still under warranty. This will b the 3rd time I take back. 1st time was the tightening of the strut nut. Second found nothing. 3rd time I found exactly what angle to hit the driveway gradient chane sona to show he technician. I will keep u posted. Good luck
Old Jun 1, 2021 | 04:03 AM
Clifforr's Avatar
Originally Posted by hello_you1
I have the same problem too, but it only can hear it on winter. I thinking is the shocks not too sure.
Hey, am having the same sound, how did you resolve yours?
kistner
Sep 25, 2018 08:33 PM
MTLian
Apr 20, 2015 03:51 PM
Lobo1101
Jun 3, 2014 06:02 PM
xcsp800
Feb 7, 2014 01:26 AM
Solscud007
Dec 20, 2012 11:03 AM
