Recommended Brand of Oil?
Old Mar 28, 2014 | 11:57 PM
2012FitFan's Avatar
Originally Posted by carolina_cruising
I will say, however, that whatever your interval, doing your first oil change early (1.5k-3k miles) is a good idea for draining any debris shed during the break-in period of the engine.
I wouldn't change it early on a Honda. Honda uses a special break-in formulation.
Top 7 Urban Legends About Motor Oil
5. When you buy a new car, change your oil at 3,000 miles to remove metal particles from the engine break-in process.
There might be a grain of truth to this, according to the experts at Blackstone. Oil samples from engines during the first 3,000 miles of driving show elevated "wear-in" metal levels, coming from the pistons and camshafts, says Ryan Stark, Blackstone's president. But he added, "To me, it doesn't make that much difference because if the filings are big enough to cause damage, they will be taken out by the oil filter."
However, a Honda spokesman says its cars come from the factory with a special oil formulation for the break-in period. Honda advises owners to not change the oil early. Stark said Blackstone Laboratories' test of Honda's break-in oil shows it contains molybdenum-disulfide, an anti-wear additive. But Stark said Honda is the only manufacturer he knows that's using special break-in oil. The take-away? If there are any special break-in recommendations from the manufacturer, follow them. And consider analyzing the oil at 3,000 miles.
Old Mar 29, 2014 | 01:51 AM
fitvtec's Avatar
i use mobil 1
Old Mar 29, 2014 | 01:53 AM
13fit's Avatar
Just to add some input, while no specific brand is best for a factory Fit, I can honestly say stay away from store brand oil. It is usually filtered and recycled oil, even the synthetic labeled bottles.
Brand names are the only way to go with oil. Walmart has Supertech, that has worked for me in the past, if cheapness is of interest.
Old Apr 8, 2014 | 11:56 PM
hspatz's Avatar
Manual says not to change break-in oil early
Where did you get that information? The manual specifically tells you not to change it early:
"Break-in Period
Help assure your vehicle's future
reliability and performance by paying
extra attention to how you drive
during the first 600 miles (1,000 km).
During this period:
● Avoid full-throttle starts and rapid
acceleration.
● Avoid hard braking for the first 200
miles (300 km).
● Do not change the oil until the
scheduled maintenance time."
Bowbridge
Mar 16, 2015 09:12 AM
FIT-tles Worth
31
Aug 17, 2014 05:55 PM
Nice Fit
Jan 16, 2012 07:59 PM
Benggolf
Jun 26, 2009 06:57 PM
rpboy06
Jun 21, 2008 03:34 AM
