CR-Z 5 lug
Old May 27, 2014 | 12:25 PM
Gingervitisman's Avatar
CR-Z 5 lug
Answer time!! Do the CR-Z front spindles and rear beam fit on the GE? Does anyone know for sure? Spindles I would think work because they *look* the same on paper, but then so does the rear axle beam. Do I just nut up and buy a CR-Z rear axle and see what happens? Or is it a better idea to just buy the Kuo's Garage 5 lug kit?
Old May 27, 2014 | 12:42 PM
Taking donations for CR-Z rear beam test! lolz
But really, I won't refuse if you want to help
Old May 31, 2014 | 01:35 AM
ajp2k3's Avatar
You have a link to the Kuo's Garage 5 lug kit?
Thanks.
-andrew
Old May 31, 2014 | 12:19 PM
They don't even list it on their site, you have to email them about it. It's 650 plus tax, shipping, brake rotors for the front and custom drums for the rear
Old May 31, 2014 | 12:20 PM
Plus it's a proprietary rear wheel bearing, that's why I'm trying to find out if the CR-Z rear beam will work
Old May 31, 2014 | 01:52 PM
13fit's Avatar
front crz hub goes on our bearing, as the bearings are the same part number
rear axle bolts right on, you gain a tiny bit of stiffness
you will need brake hoses and e-brake cables to comeplete the swap
no one in USA has CRZ 5 lug yet, I was hoping to be first lol next year
EDIT CRZ brake master is different size, might want to take measurements of our stock master and see about swappiung to a 4wheel disc one from another honda for best brake balance
Old Jun 3, 2014 | 11:43 PM
Sweet deal man, I know I'm not gonna be the first cuz I'm gonna wait til my warranty is up, but I'll definitely be doing this eventually.
Old Jun 26, 2014 | 11:45 PM
Couldn't we just use the CR-Z master cylinder?
Old Jun 27, 2014 | 10:47 AM
13fit's Avatar
CRZ master cylinder is different bolt pattern IE wider or narrower gap betweeen posts
Old Jun 27, 2014 | 10:53 AM
I have a dremel that has something to say about that... lol
Hpc90
Feb 24, 2015 11:14 AM
BlueBoogers
Aug 8, 2012 04:43 PM
SSMTEN
Sep 9, 2011 04:25 PM
vwli
Sep 1, 2011 10:55 PM
BandAidBob
Sep 3, 2010 09:57 AM
