Please help me to find a way to control windows with key fob.
Old Jun 21, 2014 | 02:11 AM
Desmond Lamar MacRae's Avatar
ok everyone knows that I'm disabled.I'd like to be able to control the power windows with key like I could do with all the rest of the Hondas I owned. is there an easy way to do this. If so explain to me how. I find myself getting out of the car but at the same time I forget to check out my windows. They are usually down 90% of the time. If no one's around it means getting back in the car to roll them back up. Im so used to jumping out of my 8th gen Accord EX-L Navi and 3rd generation Acura TL doing this that I can't get tuis pattern out my head. Is there an easy fix like swapping the power window actuator from a 14' civic or another newer car? Thanks for ony input to make my life easier when transferring to and from my wheelchair to car. Im open minded to anything.
Old Jun 21, 2014 | 03:12 AM
ikutoisahobo's Avatar
I believe there are aftermarket window automation systems, There's one called the DEI 530T, it's some module that controls the window systems and that's all I know of.
Old Jun 21, 2014 | 08:38 PM
Thank you bro. My family friend owns an electronic/car audio store. I'll get him to get a price for me. He carries that brand of electronics.
Old Jun 21, 2014 | 09:39 PM
k-man's Avatar
Check this out, these guys make them:
KP Technologies
I have their beep module on my GE, I like the beep vs honk when I lock lol
Old Jun 21, 2014 | 10:21 PM
KP Technologies
Thank you. I'll check it out. The first module a member listed only works for up to two windows. I drive with all down. I'd still be fucked if the rear windows are down. Id have to get back in the car to roll up the windows.
Old Jun 21, 2014 | 11:30 PM
Goobers's Avatar
There's a 535T model... it supposedly can control all four windows in ONE direction (you want auto up?). The 530T can control all four too (in one direction), but based on a google search, only the front two will do auto up, the rear have to be commanded to go up (via the fob). At least, you don't have to get back in the car.
I haven't seen any that control all four in both directions... the thing about the 535T/530T is that, you aren't limited to only one unit, so you can use two units... however, I'm pretty sure it (one or two units) needs to be hooked to either a security or remote starter system from DEI's brands (Clifford, Python and Viper are a few of DEI's brands).
Originally Posted by from another forum
yes you can do a 530t on 4 windows. but they will only automate in one direction. also the ground when armed will only roll up 2 of them. you will have to use the vent input to roll up the other set. or the opposite depending on how you want it.
the only reason i know this is because i had to do it one time for a shop i used to work at.
this is by far one of the stupidest things you can do. dont be an ***, buy 2 of them to do 4 windows or just do your 2 fronts only with the one module you have.
Still, it's better than the 529T (which is recommended for sunroof control) or even some other companies... 1 unit, controls two windows in only ONE direction... or one window in both directions (in other words, half the functionality of the 530T).
I ordered two 535Ts to attach to my Viper remote starter. I should have enough AUX channels to support it.
Old Jun 22, 2014 | 12:14 AM
DWils's Avatar
KP Technologies
The website says that it (the window roll up) only works with the MDX, TL, TSX, and Accord. No Fits or Civics. I'm kind of wondering if it would still work and they just didn't test it for Fits or Civics. They also say that it only works up until 2011 model years, which also makes me wonder if they just haven't updated the site since then.
Old Jun 22, 2014 | 03:12 AM
My moms 2013 EX-L Civic has it.
As far as what I want is like stock honda. Press unlock button twice and hold (windows roll down). Roll windows up turning the key in lock twice and hold (windows roll up). I was told the Viper app alarm system for Androids/ iOS can do the windows.
Old Jun 22, 2014 | 04:50 AM
Goobers's Avatar
The Viper units do have a feature called "Comfort Closure" that allows you to remotely close windows when arming the alarm, BUT it requires the car itself to already similar features as OEM (as described^). And I suspect that is why the KPTech unit doesn't support the Fit. Looking at the install procedure, it doesn't manipulate the window's wires, but the door locks instead.
For the Fit, you need the 530T/535T module installed, since we have no such OEM feature. The module can also give all windows "one-touch" up or down if you wire each in a specific way (intercepting the lines BETWEEN the door's window switch and window motor).
BrassInTheGrass
Aug 1, 2014 10:32 PM
td
May 23, 2010 03:30 PM
stenoienpm
Jun 26, 2009 12:54 AM
missvdub
Dec 12, 2008 04:25 PM
benfal2001
May 24, 2006 12:48 AM
