Murphy's law in action: snapped speed sensor wire !
Old Sep 16, 2014 | 10:22 PM
CasualFitOwner's Avatar
Wife drove over a hub cap that rotated inside the front passenger wheel well. Result => ABS light is. I pull the wheels and found the speed sensor cable cut. It's about $300 to replace the whole right front sensor harness at the dealer.
Old Sep 16, 2014 | 11:00 PM
13fit's Avatar
why would you replace the harness? grab 2 butt connectors, a crimping tool, some heat shrink, and a lighter.
Spend that $300 somewhere else, or save it towards eventual maintenance down the road
Old Sep 17, 2014 | 03:47 AM
Black3sr's Avatar
13Fit - is there just one wire in there or multiple ones? If one then your suggestion is a piece of cake. If more I looked at Bernardi and a new part is $135. The replacement is rather easy to do.
Old Sep 17, 2014 | 10:31 AM
13fit's Avatar
Its two wires.
$135? you need more then just the sensor. The sensor doesnt have all that wiring
Fix this for under $20
Old Sep 17, 2014 | 11:05 AM
yah wat 13fit said. just fix it yourself.
Black3sr's Avatar
Arrow
If it is only two wires then yes repair it. It will take longer to get the wheel off than to solder a couple of wires.
I was quoting the $135 as that was for the entire piece which includes the sensor.
Old Sep 17, 2014 | 11:38 AM
Wanderer.'s Avatar
I wouldn't use butt connectors for that just because it will move around a lot day to day when turning the wheels and stuff. Just go buy a cordless soldering iron from harbor freight and solder it back together and throw some shrink tubing on it.
I use butt connectors on plenty of things but that is not one I would use them on, that's just me though.
If you don't know how to solder here is the perfect chance to learn. I taught my 18 year old intern how to do it so if you can manage to take the wheel off the car you should be fully capable just look on youtube.
Old Sep 19, 2014 | 12:19 AM
13fit's Avatar
Ive repaired many a ABS harness with butt conenctors. you might be thinking about those caps, the ones most dumb bestbuy radio installers use.
Combined with good heatshrink, the connection will last for years and years. This break in the line also gives you a chance to reroute the wiring if you think it could be in a safer location.
Old Sep 19, 2014 | 08:55 PM
wh22366's Avatar
I passed on the $135 factory part and on the $102 NAPA price. I bought an aftermarket sensor from a vendor on eXXy for $20 (PN 57475-TF0-003 for the passenger side). You have to be very careful removing the pickup (end) from the wheel knuckle as it tends to rust in place. If you break it off, you got trouble. Also I had to sand the new pickup end until it reduced the diameter enough so it would fit in the hole.
Old Sep 20, 2014 | 12:53 AM
13fit's Avatar
He doesnt need a sensor.
Old Sep 20, 2014 | 12:41 PM
honestly i would just solder the wires together since it is on the exterior but thats just me. im sure the butt connectors work fine and give the extra length to put the wires together.
Old Sep 20, 2014 | 05:02 PM
Thank you all for the advice. I'll check if connecting the wire + battery off will turn the ABS light off. If not, will try other recommended steps here. Again, Thanks !
Old Sep 27, 2014 | 06:48 PM
Update: ended up taking it to the dealer. Here's why
- connected the wire and disconnected the battery => ABS light still on
- stripped different place and did the same => light is still on
- OBD II scanner does not bring up any code to reset
- Dealer said $100 charge to hook up their code reader
sLiVeRwOrM
Mar 21, 2023 06:48 AM
SaratogaFit123
Apr 22, 2019 09:19 PM
hill8570
Dec 2, 2017 11:03 AM
dasdavid
Apr 15, 2017 02:39 PM
tomwilley
Jan 9, 2015 08:31 PM
