Problems caused by aftermarket 12V USB adapters?
Old Sep 22, 2014 | 10:24 PM
willtonr's Avatar
Hi, I'm new to this forum. I'm wondering if anyone else has encountered this problem: The TPMS dashboard light in my 2010 Fit Sport is on, but the mechanic can't find anything wrong with the sensors. He noticed that I keep a USB adapter in the 12v charger and told me that aftermarket adapters have been known to interfere with the dashboard warning indicators, causing them to light up when nothing is actually wrong. Has anyone else experienced problems caused by aftermarket adapters? (I know I can use the USB jack in the glove box, but sometimes I need to charge more than one device.)
Old Sep 22, 2014 | 10:27 PM
xxryu139xx's Avatar
I call shenanigans! The only problem i've ran into with aftermarket usb cigarette adapters is not enough juice to some devices. anyway, take out the usb adapter. run the car. i bet you'll still have the same problem.
Old Sep 23, 2014 | 11:34 AM
my car has some generic dual charge usb adapter almost all the time in the power socket.
no issue.
why not just yank that thing off and drive it around for a few days?
if no tmps, then drive with the usb adapter and see if the error lamp comes on.
your transmitter inside your wheel might be faulty or low on battery..
Old Sep 23, 2014 | 08:54 PM
willtonr's Avatar
Yep, the first thing I did upon leaving the mechanic was to remove the adapter. It's been two days and the light is still on
Old Sep 24, 2014 | 01:45 AM
BraytonAK's Avatar
The mechanic is reaching for straws.
Old Sep 24, 2014 | 01:49 PM
take it back. im pretty sure your tpms is damaged or battery low... or missing entirely..
Old Sep 25, 2014 | 01:51 PM
4thCornerFit's Avatar
I'd get a second opinion on the TPMS light.
Most tire shops have devices which can query the TPMS sensors to see if they're sending out a good signal. They should be able to quickly tell you which, if any, sensor has gone south for the winter.
I had one go out 2 months after the car's warranty expired. Dealer wanted to charge me to diagnose. Local branch of a chain tire store identified which wheel had gone bad at no charge.
Tire shops can also replace a bad sensor and reprogram the TPMS system to use the replacement; usually at less cost than the stealership.
Old Sep 26, 2014 | 11:44 AM
^^ that's a good call on taking it to the tireshop.
Old Sep 26, 2014 | 09:26 PM
CarbonCorsa's Avatar
What is your tire pressure? Most those systems work on the % of all four tires with each other.
Did the same mechanic changes your tires? The often break them. And yes get the car tpms scanned for errors.
Tricone
Jan 18, 2019 01:04 PM
Bassguitarist1985
15
Sep 10, 2014 05:51 PM
OliviaNewtonJohn
Jul 11, 2012 08:05 PM
sofosal
Jan 15, 2010 11:19 AM
porkchop
Feb 24, 2009 01:42 AM
