Winter tires. will 205/55/16 work on stock 16" wheel?
Old Nov 7, 2014 | 04:30 PM
comatoast's Avatar
Time for snow tires is here and I would like to continue using my go to tire which is a general altimax arctic. The smallest tire they make in a 16 is 205/55/16 which is about 3/4" taller and wider than the stock 185/55/16
If it does fit without rubbbing I might change my summer tires to that size as well as they are much more common and cheaper..
Old Nov 7, 2014 | 04:52 PM
comatoast's Avatar
This is the side by side comparison.
http://www.1010tires.com/Tools/Tire-...5R16/205-55R16
Old Nov 7, 2014 | 07:42 PM
Wanderer.'s Avatar
Should be fine on stock wheels at stock height, although a less than optimal setup. But if you like the tires what can you do.
Old Nov 7, 2014 | 08:28 PM
comatoast's Avatar
I'm open to suggestions as well. I've had blizzak ws60 and ws70, winterforce, Michelin x-ice, good year ultra ice wrt, and Dunlop ice maxx. All on the same car same heavy/light snow and ice/black ice.
By far my favorites are the generals and the good years. They both perform as good or better than the Michelin's and blizzaks, and cost $40-60 less per tire. Will add the winterforces are a close 3rd. Great price and perform well
But I am open to try something new as long as they're not much over $100 per tire.
I drive about 800-1000 miles a week so treadlufe means a lot which is why I'm not interested in trying the ws80s
Old Nov 7, 2014 | 08:38 PM
Wanderer.'s Avatar
Here's a good discussion thread, just do yourself a favor and skip pages 2 and 3
I think they covered most of the tires you mentioned though, and most people are using 15" steels for winter wheels for the larger tire selection, but anyway
https://www.fitfreak.net/forums/2nd-...our-fit-7.html
Old Nov 7, 2014 | 09:32 PM
specboy's Avatar
OP, What year is your FIT? If it is a 2009 or 10, downsize to a 15" steel/alloy wheel for the winter and run the Altimax at 185/65/15. you sit about 1/4" higher off the ground but have better snow traction due to the narrower tire. With a 205, you will be floating on top of the snow instead of cutting through it. I run the exact setup I mentioned above and got my alloys off of craigslist for cheap. I'm on the 3rd winter on my Altimax Arctic snows. If you move to a separate wheel/tire combo, you won't have to remount/balance twice per year which adds another $75-$100/year's worth of cost to the winter tires.
~SB
Old Nov 7, 2014 | 11:39 PM
comatoast's Avatar
Thanks, Ill read through that
~SB
mine is an 09 Sport
I was thinking about getting 15" steelies, but couldn't find anything locally.. The TPMS light being on doesnt mean anything to me, and is very easy to ignore
Im with you on the General altimax arctics .. Best Ive ever used and couldn't be happier
What bolt pattern and width should I be looking for?
Old Nov 10, 2014 | 10:41 AM
comatoast's Avatar
Well the snow is here. Expecting anywhere from 12-16 inches thru Tuesday.
Might have to just get the blizzaks and deal with uneven / fast wear.
Steelies are not an option anymore as I see that when tpms throws a code you are unable to disengage traction control. Which is a no go for me , and the only times I've even got myself stuck was due to traction control being on.
Any positive reviews on the ws70s? I've never had them on a fit, but maybe they have better results than my previous car.
Old Nov 10, 2014 | 05:25 PM
wh22366's Avatar
I run Nokian Hakkapeliitta directional snows on 15" aftermarket alloys on all corners. This will be the fourth season for the set (with 6/32" of tread left) and I attribute the longevity to the brand and to 5K front-to-back rotations. I've used Hakkas for several decades on two and 4wd buggies and still love 'em.
fityearone
Dec 22, 2015 05:35 PM
413FitMurtz
Oct 29, 2015 08:49 AM
silentnoise713
Jun 7, 2014 09:40 PM
JDM-Taffeta-S
Aug 18, 2011 10:05 AM
ThEvil0nE
Jul 24, 2010 12:22 PM
