2009 honda fit multiple misfire codes
Old Feb 10, 2015 | 05:24 PM
Unfit2009's Avatar
Help please. 2009 honda fit stalls when not warmed up. Multiple misfire codes. I changed all coils and spark plugs performed idle learn procedure. Problem is getting worse. Check engine light is coming on more often. Getting frustrated did anyone else have same problem? If so what solved issue. Any help would be greatly appreciated.
Old Feb 10, 2015 | 10:20 PM
Santiad's Avatar
try this
seems like you replaced the coil packs and plugs...what did you replace them with?
if you torqued the plugs to spec I'd check two other things:
1) valve adjustment might be needed
2) maf sensor and air filter (do you have aftermaket intake or filter?)
either or both would have that effect on your car.....good luck
Old Feb 12, 2015 | 07:58 PM
patm95's Avatar
How many miles do you have on it? Which cylinders are misfiring? Do you live in a colder climate?
homebrew
Jul 15, 2021 11:17 AM
MIS-FIT
Jun 27, 2018 09:57 AM
nielmot
Mar 2, 2017 07:54 PM
TripleThreat
23
Jan 6, 2015 02:11 AM
CTCT
Nov 26, 2012 10:00 PM
