Anzo aftermarket headlights?
Old Jun 17, 2015 | 02:45 PM
rigwig's Avatar
Anyone have any thoughts on these?
http://www.amazon.com/SPPC-Projector...ords=honda+fit
There is only one review on amazon about them and I can't seem to find much info anywhere else. From what I read they are plug and play.
I might risk it and give them a try, worst thing I return them
thoughts?
Old Jun 17, 2015 | 04:43 PM
xxryu139xx's Avatar
no good. the projectors would suck first of all and those LEDs are not very good either. i've seen one when I was in Hong Kong and was not very impressed. its not an exact fit. someone has them here and the mounting brackets are for jdm. save your money and retrofit your headlights.
Old Jun 18, 2015 | 07:01 AM
andycampero1's Avatar
I have a pair of them,
I was actually really surprised with the projector and the led on them..
They are very strong and bright...and the projector actually gives a good output on the floor..
Of course you cant compair them to real retrofit head lights...
I own a pair as well...running tsx projectors..
Only reason i bought these other ones was because i bought them for 140 and i said what the heck ill try them for fun..planning to open them up and mess with it..
But coming from a guy who owns a pair and also has a retrofit set....
Go with a retro..
Its way better
Led on the anzo tend to burn out fast...and also when you buy them you have to make sure they are sealed correctely most have water gaps and it will get in.
So yeah xxryu139xx has a point...save and do a retro..real worth it
Old Jun 18, 2015 | 09:44 AM
rigwig's Avatar
Thanks for the replies, initially I was interested in these mostly because of the led's I might just pick up a second pair of stock lamps and try my hand at retrofitting those. I'd like to be able to swap back in the event that I either screw up, or need to revert to stock down the road.
Thanks for the input!
Old Jun 19, 2015 | 12:40 AM
connor55's Avatar
Go with a retro..
Its way better
Could you share a pic with the leds on? Curious to see.
I also think retrofit is the way to go. Dig around the for sale section of the forum and i bet you can even find pre retrofitted headlights for sale.
Anthony_gk5
Dec 5, 2022 10:22 AM
dtinyfit
Jul 3, 2014 02:57 PM
FIT504
Mar 15, 2012 11:54 PM
1SickVeilsideZ
Nov 8, 2011 12:39 AM
evojensa
Feb 14, 2006 01:22 AM
