accessory plug always on
Old Sep 29, 2015 | 12:35 PM
bensenvill's Avatar
is there an easy way to rewire the car so the accessory plug always stays on?
Old Oct 1, 2015 | 07:16 AM
DWils's Avatar
Two ways I can think of. The first would be the easiest and it consists of adding another auxiliary power plug, wiring it to a ground and some fuse that is always "hot" by way of an add-a-circuit. The second way would be a little more labor-intensive as you would have to remove the center console, remove the power plug, snip the power cable and rewire it from the plug to the fusebox using the previously-mentioned add-a-circuit then put everything back together.
Triskelion
Sep 23, 2022 02:58 AM
Carl Gerhold
Dec 13, 2020 11:10 PM
FitFly
Oct 28, 2013 01:16 PM
mxl180
Jul 14, 2012 07:42 PM
Gumbi
Feb 16, 2009 01:42 PM
