Coolant change - can I use my radiator pressure tester
Old Aug 15, 2016 | 09:33 AM
Jutboy's Avatar
Question Coolant change - can I use my radiator pressure tester
Hello everyone,
I have a radiator pressure tester and I was wonder if I could use it to help with changing the coolant on my 2010 Honda Fit Base Auto?
If so, what would be the best procedure? Thanks for your help. The kit looks like this : https://images-na.ssl-images-amazon....L._SL1500_.jpg
-J
Old Aug 15, 2016 | 02:37 PM
dwtaylorpdx's Avatar
Dont put more than about 18-20 lbs of pressure in the system, the factory pressure is 16 ish. Whenever you pressure test a engine take the plugs out, and crank before putting them back in just in case you got water through a head gasket. Prevents hydrolocking the motor.
Cheers
Old Aug 15, 2016 | 04:01 PM
Jutboy's Avatar
So should I just not use the thing at all or should I try pushing the old fluid out with low pressure? If I use it should I fill up the reservoir and apply pressure there with the drain plug open on the radiator?
I haven't done this procedure before, just want to be safe.
Wreck Ignition
Mar 14, 2024 03:24 PM
mxl180
Sep 21, 2014 10:38 PM
pastafarian
Mar 3, 2008 09:01 PM
Krystyne
Sep 30, 2005 04:36 PM
Elle
May 4, 2005 04:44 PM
