Driver side airbag : Should it be like this after replacement ?
Old Oct 4, 2016 | 01:10 PM
Odie's Avatar
Driver side airbag : Should it look like this after replacement ?
The gap looks a bit too large . Also check the electrical connection cover on the bottom of the steering wheel when replaced .
Attached Thumbnails Driver side airbag : Should it be like this after replacement ?-dscf7949.jpg   Driver side airbag : Should it be like this after replacement ?-dscf7950.jpg   Driver side airbag : Should it be like this after replacement ?-img_0049.jpg   Driver side airbag : Should it be like this after replacement ?-dscf7922.jpg   Driver side airbag : Should it be like this after replacement ?-dscf7920.jpg
Driver side airbag : Should it be like this after replacement ?-dscf7919.jpg
Old Oct 4, 2016 | 01:44 PM
Hondu's Avatar
No. Go back to the dealer.
Old Oct 4, 2016 | 03:04 PM
Odie's Avatar
Others with the new airbag installed should look for these flaws as well .
Old Nov 2, 2016 | 06:11 PM
Satchel's Avatar
Had mine done last Friday...the panels look untouched and like they did when I took it in.
Old Nov 2, 2016 | 06:32 PM
Codger01's Avatar
I looked for that issue when I picked up my car today after having both airbags replaced. It doesn't look like they had to take anything apart at all.
Old Nov 2, 2016 | 07:38 PM
dwtaylorpdx's Avatar
Thats ugly. Cant believe that car made it back out the door.. GO STRAIGHT to the service manager and ask what your free loaner car will be..
Old Nov 3, 2016 | 12:57 PM
Odie's Avatar
Could someone take a picture of the driver airbag cover at same angle ( shown below ) that's not replaced yet or those after fix for a comparison ? The tech replaced it less than 35 minutes . Should that be of concern ? The panel on the bottom of the steering wheel was replaced at no cost . Click pics to enlarge .
Attached Thumbnails Driver side airbag : Should it be like this after replacement ?-dscf7952.jpg   Driver side airbag : Should it be like this after replacement ?-dscf7949.jpg   Driver side airbag : Should it be like this after replacement ?-dscf7950.jpg
Old Nov 4, 2016 | 12:48 PM
fitchet's Avatar
I don't even know why you have to ask.
That's ugly...and simply not right.
I'm usually against outright complaining. But I'd outright complain.
Return, be appropriately annoyed, and ask to see the service manager.
That's an unacceptable level of repair especially for something as important as the airbags.
Old Nov 4, 2016 | 01:42 PM
bob89's Avatar
EDIT. Actually, the gap on top of your steering wheel is normal, I think. Sorry about the misinformation. I just had my airbag replaced too and the gap on my steering wheel stayed the same.
However, the bottom panel in your picture is definitely messed up. They should fix that.
Old Nov 4, 2016 | 03:33 PM
Odie's Avatar
There may be others with the same gap that went to the same service department and are not aware of it .
Old Nov 7, 2016 | 09:48 PM
doctor J's Avatar
Send the pictures to the state department of consumer affairs. Hopefully the stealership will fire the manager and incompetent technician
jiko
Mar 20, 2013 02:06 AM
hondafitblue
15
Feb 9, 2010 12:53 AM
bosshogg
Aug 31, 2008 05:17 AM
sparkedfire
Dec 2, 2007 12:11 AM
butch burton
Oct 8, 2005 01:33 PM
