spark plug advice - 2010 Fit - stick shift.
Old Mar 23, 2018 | 07:25 PM
Fitnjammin's Avatar
hi everyone! Newbie here. I have to do a long overdue spark plug change - K175+ miles on the same plugs! It runs fine but you're all jaws on the ground saying "Whaaaat??" I am mechanical and have all the tools and plugs - NGK Iridium IZFR6K13. There are several videos on YouTube- taking the mounding and windshield wiper motor seems the easiest option. The only thing I'm worried about is the threads in the cylinder head. Obviously I'll do it with the motor cold. Has anyone experienced thread problem under the same circumstancess? Any advice will be appreciated.
Old Mar 23, 2018 | 08:40 PM
spike55_bmw's Avatar
If the car has gone 175K+ miles without the Check Engine Light coming on and giving you a code indicating a misfire, it would seem that you don't have a spark plug thread problem.
Some, but not all of us, have had a spark plug work loose over time (#2 & #3 in my case on a new car) and if not fixed right away, the hot exhaust gases erode the threads that are already misaligned (reason the spark plug came loose). After the erosion occurs, the threads are damaged and need repaired.
Again, if your plugs are still tight, it wouldn't seem to me that you have a spark plug thread problem needing repairs (based on my interpretation of your post).
Old Mar 24, 2018 | 01:24 AM
Fitnjammin's Avatar
thanks for the info
Old Mar 24, 2018 | 01:34 AM
ezone's Avatar
That's no big deal IMO. Precious metal plugs wear so slowly, most could outlast the cars they are installed in as long as they don't get fouled out.
Make sure you install your new plugs tight enough.
Too loose can lead to all sorts of problems.
Old Mar 24, 2018 | 04:37 AM
I'd like to confirm that your 175K miles on the same plugs also means 175K miles on the same coil packs electronically firing those plugs.
If so, it is a testament to the longevity of the coil packs flawless operation. On the forum, I've seen several owners automatically change out all four (4) coil packs (approx $170 ea at my dealer) as a "wear item" at 100K miles, for example. If they are working, keep using them.
As you noted, the car works fine but I would have changed the plugs out at 100K miles. I have a bunch of motorcycles and each wear out their spark plugs at different rates, so I change the plug with any major service.
Old Mar 24, 2018 | 11:47 AM
Fitnjammin's Avatar
Thanks ezone and Spike55
Old Mar 24, 2018 | 08:30 PM
perkidddoh's Avatar
Hey man! I just finished my first spark plug change and valve adjustments on my '13 Fit at 66k miles this morning. There shouldn't be a problem with the threading as long as you are first hand tightening the spark plugs.
Also, a magnetic spark plug socket would be super helpful for this, that cost me a little under $7 at my local autozone.
Old Mar 27, 2018 | 07:47 PM
Fitnjammin's Avatar
Thanks for the info
Triskelion
Sep 23, 2022 02:58 AM
doctor J
Jan 22, 2019 11:45 PM
Bryanfit
19
Mar 17, 2017 02:03 PM
CarbonCorsa
Oct 22, 2014 04:00 PM
ikrash
Oct 31, 2008 06:24 PM
