What is it?
Old Apr 14, 2018 | 08:47 PM
JamesU's Avatar
What is it?
I just bought a 2013 Fit for my daughter. I found this part in the back.
What is it? It is marked TK6 L 889 but searching for that part number does not give me any clues. It is flexible and made of black rubber.
Thanks!
Old Apr 14, 2018 | 09:06 PM
ezone's Avatar
That is called a "strake", there were a pair, they were supposed to come with pushpins and it was to be installed in the front of the rear wheel in the bottom corner of the fender.
It's basically a little air deflector that hangs down below the body line in front of the rear tires.
If you only found one inside the car, check if the other is still attached to the car so you can see how it's installed and held on
Old Apr 14, 2018 | 10:45 PM
JamesU's Avatar
Awesome - Thanks. I'll poke around and see. I have some push pins so it should be pretty easy to put on, I think.
Thanks!
adock22096
Jan 12, 2018 08:25 PM
ChrissyW
Feb 7, 2014 06:25 PM
Rachelsfit
Mar 11, 2011 03:58 PM
RachelWin
Mar 11, 2011 03:54 PM
alanchan
Jul 19, 2010 01:45 AM
