Oops I loosened the wrong bolt trying to drain the engine oil
Old Dec 18, 2018 | 06:24 PM
Davethegoat's Avatar
Does any one know the torque specs for the 17mm socket head bolt on the automatic transmission that I mistakingly loosened thinking it was the oil drain bolt
Old Dec 18, 2018 | 06:43 PM
evilchargerfan's Avatar
step 1:
-Googled it
Step 2:
-Found relevant result and clicked said result
Step 3:
-Profit
(duplicate answer, from duplicate post = https://www.fitfreak.net/forums/gene...ml#post1419693)
Old Dec 18, 2018 | 08:43 PM
Those are not the bolts I loosened. Thanks I'm aware of google. If anyone has the spec for the bolt I mentioned I would greatly appreciate it.
Old Dec 19, 2018 | 12:24 AM
Goobers's Avatar
Saw this thread earlier, but had to wait to get home to look it up in the service manual.
33 ft*lb
And yes, as mentioned in the OTHER thread... posting the same topic more than once is typically considered spamming. So, consider picking the most appropriate sub-forum for the topic and just post it once.
Old Dec 19, 2018 | 07:58 AM
Great thank you for your help
I wasn't spamming I just didn't know what subforum would be most appropriate for the answer. Not to say there isn't confusion with all the different sections and whatnot. Might have been easier to have fewer choices?
Davethegoat
Dec 19, 2018 11:34 AM
Davethegoat
Dec 19, 2018 08:03 AM
dbcmaster
Jun 8, 2014 06:34 PM
ACMierzeje
18
Apr 14, 2012 04:43 PM
ccl088
Mar 8, 2009 03:03 PM
