Where can I find the Rear Trailing Arm Bushings?
Old Dec 23, 2018 | 02:43 PM
Dougfit's Avatar
I have a 2009 Fit Sport and trying to find the Rear Trailing Arm Bushings. I cannot find them, the shop cannot find them. Anyone know where I can get them? All the listings seems to be for civics.
thanks
Old Dec 24, 2018 | 12:27 PM
evilchargerfan's Avatar
cant help on the Where To Buy portion, but here's something that may aid you on the install job
to be continued ...
Old Dec 24, 2018 | 12:28 PM
part 2:
Old Dec 24, 2018 | 01:09 PM
Dougfit's Avatar
Great instructions but strange no part number on them. Thanks
Old Dec 24, 2018 | 01:47 PM
Dougfit's Avatar
Talked to the Honda dealer and he said it is all one piece and have to but this entire then at $1,000! Your image they seem removable?
Old Dec 25, 2018 | 06:07 AM
Black3sr's Avatar
My question is.. why do you want to replace them? It would seem they last a long time.
Old Dec 25, 2018 | 02:52 PM
Dougfit's Avatar
They are creaking like crazy. I just put all new shocks on and it is still loud. I guess I replace the control arms and see which was the loud one.
Old Dec 26, 2018 | 06:27 PM
Dougfit's Avatar
Honda is saying it is all one piece. And it's a grand. He said I could try part #4 or #5. Any thoughts?
Old Dec 26, 2018 | 06:40 PM
#5 is the piece that sits under your springs, correct?
IE, that is not apart of the trailing arm itself?
Old Dec 26, 2018 | 06:42 PM
Dougfit's Avatar
Yep under the spring . I know that is not the arm but it may be causing the noise is what I meant.
Old Dec 26, 2018 | 06:45 PM
1 grand seems steep btw, it should be 800 tops, or less if you go through ebay, or check google shopping results
Old Dec 26, 2018 | 06:47 PM
I have doubts that is the cause, I've gone through 2 coilovers, and 3 sets of lowering springs, and that piece has never gave me issues. but .... if you insist on replacing those, good news is, the part is cheap
Old Dec 26, 2018 | 06:48 PM
Dougfit's Avatar
Yeah found it for under 800. Only paid 5k for the car so no way.
Old Dec 26, 2018 | 06:51 PM
one more thing, I did recently replace my bushings on the Rear Beam ... if you're interested in going that route .... here ya go:
https://www.fitfreak.net/forums/3rd-...ml#post1420181
The product/bushings:
https://powerflexusa.com/hondafit201...ngbushing.aspx
Old Dec 27, 2018 | 11:44 AM
Dougfit's Avatar
Well any other ideas on what it could be?
Old Dec 27, 2018 | 01:46 PM
going off of your 1st post:
" I have a 2009 Fit Sport and trying to find the Rear Trailing Arm Bushings. I cannot find them, the shop cannot find them. Anyone know where I can get them? All the listings seems to be for civics.
thanks "
no clue. not enough info provided (changes to the car? mileage? etc). but heck.... ill take some shots in the dark anyways.... i'm in a good mood:
-springs rubbing on something
-exhaust rubbing on something
-exhaust hangers rubbing on something
-something else, is causing the creak ... something unrelated and not mentioned as of yet .... and may never be mentioned, unless more info is provided and/or the op does more investigating
-you're right, and you really really need to replace that rear trailing arm
Old Jan 5, 2019 | 09:05 AM
sarasube's Avatar
on their website it says that bushings are for GK, i assume that it will fit GE.
nice write up
thanks
Old Jan 5, 2019 | 11:29 AM
Dougfit's Avatar
Thanks a lot for this looks promising. Just put the new control arms on yesterday and they doused everything with grease. Going to see how it goes. That doesn't work going to keep figuring out. This may do it. Thanks again
Old Jan 7, 2019 | 01:13 PM
updates? hopefully ya figured it out
Old Jan 7, 2019 | 01:22 PM
Dougfit's Avatar
Just got the new control arms on a few days ago. But I'm a government contractor so I haven't exactly been using my car. In fact I haven't driven it at all. I will let you guys know though. Thanks
