3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Urethane Bushing Kit for GK5?
Old Nov 21, 2018 | 02:52 AM
cybonic86's Avatar
very nice, i am waiting to install my hardrace bushings on the 30th
Old Nov 21, 2018 | 01:21 PM
evilchargerfan's Avatar
ebay gods have heard my cry for help!
https://pages.ebay.com/promo/2018/11...08183455912173
Old Dec 17, 2018 | 01:39 PM
FINALLY installed the bushings onto my spare/new control arms. Also, installed Megan RCA's same time.
First immediate impression, the car seems to drive more stable now. It's pretty spooky (in a good way).
I tried to take my favorite loop-the-loop on ramp at the usual speeds (40-50 mph) but due to other cars on the road this morning (esp the ones that take the turn, and occupy 2 lanes instead of their own .... smh), I couldnt get the car up to full speed and really test thing thing out. BUT .... one thing is obvious, the usual feeling of play/deflection is greatly reduced ... and I can take aggressive turns with MUCH confidence!!!
Old Dec 26, 2018 | 04:32 PM
rears went on ... I must say I had a blast removing the oem bushings and giving my new toys (dewalt drill and dewalt reciprocating saw/sawzall) a spin for the first time. props to codeman again, for the tips and making this a smooth install. the one "pita" moment was getting it all to line up, it did take me a good 4-5 tries until it all feel into place. for those interested in how the install went, it was something like this:
-jack up the rear end
-remove wheels
-release brake lines as needed
-remove bolts so the rear beam and swing down
-drill holes into bushings
-saw the bushing so the plastic ring is gone
-tap out the bushing with a hammer + chisel/flat head screw driver
-clean up the area, and then insert new bushings
-line it up, and pray it not a pita
-bolt everything back up
-profit
such a satisfying moment when it finally pops out
Impressions/reviews to follow in a few days/weeks
Old Jan 7, 2019 | 05:52 PM
IMPRESSIONS:
-car rides as smooth as eggs on the highway, esp above 65 mph. feels more firm, less prone to road imperfections (or the wind) knocking the car around. that "squirm" that I was once used to, is gone
-used to get alot of rattle noises from the exhaust hitting metal, most of that is eliminated
-can turn/corner sharp as heck now, and with insane high speed .... with mega confidence
Final Thoughts = this mod is most def worth doing.
Old Jan 30, 2019 | 05:05 PM
Mee Boc's Avatar
Thanks for the info and install notes @CodemanGK5 @evilchargerfan !! Looking forward to this mod
Old Jan 30, 2019 | 05:17 PM
good luck! its such a worth while mod, its life changing!!!!
Old Jan 26, 2021 | 01:34 AM
RA092724's Avatar
Could the Megan RCAs fit into the OEM LCAs? I just tried buying some Megan RCAs on ebay but the seller cancelled my order saying they “wouldn’t fit the OEM tire rods”
Old Jan 26, 2021 | 10:22 AM
CodemanGK5's Avatar
They 100% fit oem lcas. Tie rods have nothing to do with it.
Old Jan 26, 2021 | 10:31 AM
RA092724's Avatar
Thanks CodemanGK5! I was looking at the RCAs since i’m considering putting RS-R super down springs on the OEM struts. I’d love to eventually do the bushes but for now it seams from what i’ve read the RCAs are necessary for adding lowering springs.
Old Jan 26, 2021 | 10:35 AM
CodemanGK5's Avatar
You got it! Definitely best to do RCAs when lowering to help correct suspension geometry.
No idea what that seller is talking about. Like with any suspension mod an alignment is necessary afterward which will involve adjustment of tie rods, but theres no issue caused by them with the RCAs
Old Jan 26, 2021 | 12:06 PM
  #32
RA092724's Avatar
I really appreciate it. I just bought some Megan RCAs from a different seller and of course triple checked that they are for the GK5. Definitely, will do the alignment afterward.
Old Apr 27, 2022 | 12:13 PM
  #33
FAT BASTARD's Avatar
got all of my bushings in and spare front LCA. Cant wait to install it all and see how she does next track event! Thank you guys for the install instructions!
Old Jun 17, 2022 | 05:13 PM
  #34
seattleguy's Avatar
What brand bushings you guys using?
s anyone getting squeaking from the urethane?
Old Jul 19, 2022 | 08:39 PM
  #35
GK5 Sport's Avatar
Spoon does solid rubber if you're not a fan of poly. $$$$ though.
https://spoonusa.com/products/make/fit
Old Jan 14, 2023 | 09:48 AM
  #36
Skpdat's Avatar
Great work! Thank you for doing all the hard work to post the install.
bjosuesr
50
Feb 1, 2023 11:48 PM
owenxguo
17
May 13, 2022 08:20 PM
PJ Villaflor
May 12, 2020 04:26 PM
PHNTMONE
Feb 18, 2015 01:43 PM
Jelani
Jan 8, 2015 08:26 AM
