Any suggestions on how to resolve battery issue?
Old Dec 29, 2018 | 01:53 PM
Steve244's Avatar
Originally Posted by cgwaters
My wife has a 2013 Honda Fit Sport that has been having battery issues. If the vehicle isn't started for more than two days, especially in the winter (we live in the Northeast US), the battery goes nearly dead and doesn't have enough power to turn over the engine.
AAA replaced the battery the first time the issue occurred, about two years ago.
The issue occurred again 18 months ago (Summer 2017) when we were away for about 10 days. AAA jump-started the vehicle and determined the battery was still good.
The issue occurred again last winter; AAA jump-started the vehicle and determined the battery was still good but that the dome light had been accidentally left on overnight--likely draining the battery.
The battery was dead again last week, after the vehicle hadn't been started for three days. Connecting a Battery Tender charger overnight enabled the vehicle to start in the morning and throughout the day.
The battery is dead again tonight, after the vehicle hadn't been started for three days. I've connected the Battery Tender again.
An suggestions on how to further troubleshoot and resolve this? It's not practical to keep connecting the Battery Tender. Could the battery have been irreparably damaged (despite what AAA says) when we were away for 10 days or when the dome light was left on overnight?
I'm curious about your wife's driving pattern. No I'm not a stalker. Is it mostly short trips?
All lead-acid car batteries sulfate quickly when not at full charge. If her daily drive is limited to a few miles, then expect a battery replacement in less than 2 years. The added drains (remote starter, allstate nanny) probably contribute to this state. A battery tender would help this, but the cost of this, and the hassle of installing with a plugin (and plugging it in all the time) is more effort than it's worth. Unless it's done daily, the battery is at partial charge and sulfating, which kills it.
Unfortunately, Honda chose to put small capacity batteries in this car so there's not much margin for failure, especially in a cold climate. If this latest fix doesn't hold, consider replacing the battery in the fall each year. NAPA sells a good battery, reasonably priced (under $100), in the correct size.
I'm not a fan of sandwiching larger batteries in there (requires some modifications) but this is an alternative that would give longer battery life.
Old Dec 29, 2018 | 07:59 PM
justus's Avatar
Yes, It wouldn't hurt to disconnect the remote start.... just to rule it out...
But, yeah, short trips kill batteries.... and kill cars.....(more so, older vehicles) but, stilll a car needs to be run at Operating temps.....(help burn out the junk...)
In getting a new battery...... Do it..... and leave remote start disconnected for some time........ bring it into the picture down the road.....
After you are comfortable that is seems the new battery is behaving (as new batteries should)
Old Dec 29, 2018 | 09:47 PM
cgwaters's Avatar
Thanks for the comments, everyone.
So the battery was replaced yesterday afternoon. The mechanic didn't touch the remote starter but did keep a load monitor connected to the vehicle overnight. There was no drain whatsoever. Problem appears to have been solved.
At this point, we may never know what the root cause is/was--in particular, why did the problem became significantly worse the last few days. As I mentioned, I unplugged the OBD device two days ago and will not be plugging it back in.
My wife does a mixture of short drives and long drives. Over the last few months, it's been mostly long (45-60 minute) drives.
Old Dec 30, 2018 | 02:25 AM
Pyts's Avatar
I'd be chasing wires like crazy, listening to the alternator pulley.. that remote starter would have to tap into an 'always hot' circuit, have a little relay and go to the ignition wire, no? I'm no electrician and hardly a mechanic.. but I'd check under the fuses in the engine bay just to see whats up.. i wonder if a crappy connection or relay could allow power from the battery to bypass the ignition, giving power to junk in the cab. Maybe consider, with the car off, popping out relays and jumpering with that multimeter of yours to see whats live, maybe mark the hot relays with a bit of tape. could give you or your mechanic a starting point. Itd have to be an always hot circuit if the battery and the alt are both perf, wouldnt it?
it sounds like you're good to go already, but maybe this'll get the gears turning for someone else.
Old Dec 30, 2018 | 01:07 PM
Steve244's Avatar
There should always be some drain on the battery. Various systems stay awake to operate remote entry, maintain radio presets (and anti-theft), and retain volatile memory in other control units. This is called a "parasitic" load.
The Fit service manual specifies this load to be 200 milliamps (mA) or 0.2 amps when all the systems are "awake." Most go to sleep after about 40 seconds of inactivity (i.e. no door opened) and the load drops to 35 mA (0.035 amps). Disconnecting the battery negative cable and putting a multimeter in between this cable end and the battery should give you an accurate mA reading. Be careful not to overload the multimeter as these typically only handle a few amps maximum. Trying to start the car in this mode will burn out its fuse. There are more clever ways of doing this that involve more expensive test equipment.
If something is sending a sporadic signal to any of the car's control units, these will remain awake and draw at the higher amount (10 times higher) than when asleep. I'd be concerned this is happening with the aftermarket devices (remote starter, insurance nanny). Or the devices themselves may have a high load (the remote starter has to keep a radio receiver powered up to listen for start requests).
Your mechanic may be using a load monitor typical for checking starter load which measures in the 100s of amps and not registering the parasitic loads.
I read once (may have been here) that car designers allow for 3 or 4 weeks parked in sub-freezing temperatures and still have enough battery reserve to start the car. Hondas are no different, but have less of a margin due to the tiny batteries.
151r batteries are about 45 amp-hours in capacity. A 0.2 amp draw (200mA) will drain it in 225 hours (9 days). 0.035 amp draw (35mA) is 1,286 hours (53 days). Not sure how much remaining capacity is needed to actually start the car. This depends on the ambient temperature and other factors but you can see how a 200mA (0.2 amps) will deplete the battery in about a week. This is when the battery is new. As it ages it has less capacity due to sulfating which occurs more rapidly when the battery isn't maintained at full charge.
Old Mar 18, 2023 | 04:44 PM
MagicalSeats's Avatar
I’m surprised nobody has mentioned the ELD equals electronic load detector or some auto places call it The battery current sensor.
in any event there’s a TSB on certain Honda models to replace the ELD due to faulty soldering. But as with other TSB’s I’m pretty sure it Should have extended to other models with possibly different part numbers but that are similar and that are not listed on the tsb.
On the Honda Fit it doesn’t seem extremely common but with high mileage fits somewhat common for the ELD to go bad and this could cause battery issues Such as not recharging properly or parasitic drain.
Lastly I just wanna say that despite the Honda Fit having one of the smallest weakest batteries as a stock battery it should not die overnight or even after a couple days of sitting that means you likely have a parasitic battery drain or problem recharching Not related to the alternator if the battery and alternator tests good and it could be the ELD (or battery current sensor).
Old Mar 19, 2023 | 10:15 PM
Mister Coffee's Avatar
I've been thinking about this statement. The Honda OEM battery is not just small and weak; it is inferior in quality. I've been getting more confident starts from my Interstate 151R. The Interstate 151R is also better than the Duralast Gold 151R.
Old Mar 19, 2023 | 11:08 PM
cutsheal5's Avatar
This thread is from 2018…… also the OEM battery is more the adequate, I live in Canada and I have had an oem Honda battery in my car for 5 years with no issue. The big issue here is not the size of the battery it’s not buying a factory Honda Battery (which are no more expensive than aftermarket but way higher quality).
Old Sep 17, 2024 | 11:07 AM
ve6cmm's Avatar
Unhappy Battery and phantom Drain issues
I have had a problem with my 2013 Fit for some time now. This occurred over the winter and has left me high and dry a few times. The battery would be dead after 2 days of sitting idle. This never seemed to be a problem before. I replaced the battery as it was original and thought that was it. But it wasn't. I had a phantom lead of about 60 milliamps which didn't seem like a problem. Unfortunately, it was as I could leave the car alone for 3 or 4 days, and then the car wouldn't start. I checked the phantom drain again and found that I now had a 300+ milliamp drain and figured that the only thing that could be the problem was the radio as it contains the remote lock system, clock, and a few other things that are powered up all the time. I proved this by pulling the radio fuse and the phantom drain dropped to ZERO. So now, I am going to have to pull the radio and see if i can find what's wrong. I have 50+ years in the electronics industry designing and servicing electronic systems. Hopefully, the radio isn't so tightly put together that it is repairable!
Old Sep 17, 2024 | 11:14 AM
Pyts's Avatar
@ve6cmm Awesome work!! Thank you for sharing. I'm not much of an electronics guy, so when those faults pop up I have a hard time getting into the mindset for thoughtful troubleshooting.
Old Sep 17, 2024 | 11:56 AM
@ve6cmm Nicely done, sir. Looking forward to your followup.
Old Sep 18, 2024 | 08:15 AM
  #32
ve6cmm's Avatar
I spent a couple of hours yesterday trying to locate the problem. Sure enough, when the RADIO fuse is in place, the phantom drain goes up to 0.25 amps, more than enough to cause problems if the car sits for too long. Further investigation proved that the Bluetooth module is the problem. Pull the bluetooth module and the drain drops to about 0.05 amps. I'll tell you this though, the manual sucks when it comes to the fuse panels in the fit, and working on the one under the dash is very difficult, especially when you are in your late 60's and don't bend very well!
I'll be looking at the bluetooth module over the next few days to try and figure out what went wrong. My initial look doesn't show anything unusual such as over heated components, and of course, there's no information on the module that I have found yet.
Old Sep 18, 2024 | 06:49 PM
  #33
56chevydan's Avatar
This post basically hits on two points. First, our Fits were offered with a weak, very small case battery. These batteries are marginally ok in the best of circumstances. The second issue is that a milli-amp drain can occur and can quickly cause the original size batteries to run down quickly in power- to the point the car won't start. The Civic 51 battery is, in my opinion, only marginally better than the Fit 151 battery. When I tried to fit a Civic battery into my car, it had clearance problems- touching the driver's side headlight housing to the outside and also touching the air cleaner housing to the inside.
So, in 2019, I visited my local Walmart store and found a full size battery that would fit the Fit in their battery catalog- which listed case and dimension sizes. I found that a 26r battery would fit with some work/ modifications to the original Fit metal battery tray. There is also a little work needed to clearance the pos battery cable to the post due to a slightly different positioning of the battery post where it comes up out of the battery case. Once installed, it had clearance all the way around it and was rated at 665 ca and 540 cca. I've had the battery in my car since 2019 with absolutely no problems. I'm not sure when this battery case size was originally developed/ made, but in my opinion this should have been the battery that was originally offered in our cars- if it was available back then,
Old Sep 19, 2024 | 10:41 AM
  #34
ve6cmm's Avatar
The battery I installed is a #51. It has over 400 cold cranking amps and quite a large reserve capacity. It took a bit of metal cutting to get in installed. I checked the parasitic drain again, and without the bluetooth adapter installed, the drain is less than 0.05 amps. With it installed, I have seen it as high as 0.4A and usually around 0.25A, both of which are much to high. Honda states the drain should be around than 0.05A. I don't think we will have any problems with the battery dying on us at this point.
I read somewhere that there is a law suite against Honda for this problem. It was launched a few years ago. I haven't seem anything else about it so maybe this was just BS. Apparently it was for modules for the FIT only and for years up to 2015. I'm wondering if maybe there is a hidden warranty for this module.
beatricethecat
Jul 7, 2018 04:27 AM
pzriddle
Jan 23, 2015 06:31 PM
hogwylde
May 27, 2013 06:18 PM
mozarwasagenius
Oct 25, 2009 07:03 PM
ccaleb02
Nov 29, 2008 09:56 AM
