ECM / PCM 83-1 Error Code,,,Ideas ?
Old Jan 5, 2019 | 02:57 PM
homebrew's Avatar
Angry ECM / PCM 83-1 Error Code,,,Ideas ?
2009 Fit, 110,000 miles. Occasional stalling or trouble starting.
Just replaced ignition coils & plugs.
83-1 ECM / PCM Relation Malfunction
P 0303 Cyl 3 Misfire
Do I need to spend $1000 for a new ECM ?!?!
Thoughts ?
Old Jul 14, 2021 | 04:02 PM
Reorx's Avatar
Thoughts ?
any luck with this?
Old Jul 15, 2021 | 11:17 AM
cutsheal5's Avatar
Originally Posted by Reorx
any luck with this?
I’ve recently had two ecu failures due to faulty fuel injectors that short out and cause a misfire as well as fry the Ecu, with the injector clips all off the Injectors and the ignition In the on position the voltage from power to ground at the injector clip should be 7.4v injectors should read approximately 10ohms of resistance. If you have any more or less than 7.4v at the injector clip the ecu has failed and will need to be repaired, I’m working on a fix right now.
Alex Smith
18
May 21, 2024 09:56 PM
angus.mundy
May 17, 2018 11:45 AM
drb53
May 31, 2017 10:40 AM
Irishgogirl
Oct 28, 2015 03:46 PM
Unfit2009
Feb 12, 2015 07:58 PM
