09 Fit speaker install question
Old Sep 14, 2008 | 12:53 PM
mdbrich's Avatar
Ok, so i went to put in some new speakers I have lying around the garage. the Fit has the same size speaker. So i take the door panel off and to my suprise
The 2009 fits speaker, is the speaker frame and the mounting device built into the speaker. So when you remove the mounting device (Speaker) you get nothing to put another speaker into except one hole a the top and a metal door frame....
Let me know if this is how it works on the previous fits. And what can i do to remedy this.
Old Sep 14, 2008 | 01:00 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
pics please. i'd like to see what your talking about. and what size speakers are they?
Old Sep 14, 2008 | 01:13 PM
mdbrich's Avatar
My door is back on already. So i dont feel like taking it off to take pictures at the moment
Old Sep 14, 2008 | 01:18 PM
secondspassed's Avatar
I think I've heard of people cutting out the actual speaker part and mounting aftermarket speakers in that space, remounting the old speaker mount on the '08s. I'm not sure if this is the same deal?
Old Sep 14, 2008 | 01:21 PM
koolkevin1107's Avatar
this is the exact same thing with the 2007-08 fits. The speaker and bracket are built into each other. You have 2 options:
Buy spacers that are made for the fit either from crutchfield.com or ebay. However u will have to drill 4 new holes to mount it which i know u don't want to.
Second option is what i did for my 2007. I took my dremel and cut out the factory speaker at the little "legs" that holds the magnet of the speaker together. I then cut out the terminal and soldered those onto the new speakers. I then took the speakers and lined it up to the stock bracket and just put 4 screws in every corner. I then just took the speaker bracket and clipped that back into the car, no new screws to drill and fits like oem.
If u don't get what i'm talking about, here is a little writeup of someone doing the same option i did.
https://www.fitfreak.net/forums/fit-...er+replacement
This is the better option. Yes u will have to ruin ur oem speakers but honestly, when u sell the car are u going to go and remove all the speakers? nawww lol.
Old Sep 14, 2008 | 01:52 PM
mdbrich's Avatar
Alright thanks guys. Yeah thats exactly what my speakers look like... lame
Anyway I am going to charge my dremel. Go buy some door fabric and come back do the doors and install my speakers!! yey gonna be a whole new look and sound to it today.
Old Sep 14, 2008 | 04:45 PM
mdbrich's Avatar
I am doing the door fabric right now. And I ran into a problem of the curves being to sharp for the fabric to wrap around without excess room for the fabric to curve correctly.
Old Sep 14, 2008 | 06:00 PM
mole177's Avatar
i can be wrong but they look like 5.25'' from the outside.
Old Sep 14, 2008 | 09:28 PM
thecheese98's Avatar
Can anyone please confirm the size of the speakers I am looking to buy a component speaker system for the 09 fit and would like to know which size I should buy any ideas? Thanks.
Old Sep 14, 2008 | 11:14 PM
mdbrich's Avatar
just installed mine in the factory today. Make sure to get one that is has a low profile in the front. The door where the speaker is has an inwards curve and runs into my tweeter on the speaker.
I took the speaker out of my s2000 which is a 6.5 i do believe
Old Sep 15, 2008 | 04:52 AM
JDM_DOHC_SiR's Avatar
The speaker size 07/08/09 Fit is 6.5 inch or 17mm and they all use the same addaptor ring...
Here is a same of what you might need to install a set of aftermarket speakers
Old Sep 15, 2008 | 06:08 PM
RA272's Avatar
Very cool--- do you happen to know if these spacers are available in the States? What sort of material are they made from?
Old Sep 15, 2008 | 06:15 PM
The upper one is made from HDF and has some sort of sound deadening spray over it, and the Pioneer on is made of a very high quality plywood that is laminated... ALPINE also makes one similar to the Pioneer one...
I have heard of a few shops in So-Cal that have orderd the Pioneer ones before... ( I forgot the name...)
PM me for more info..if you want.
Old Sep 15, 2008 | 08:18 PM
fliptwister's Avatar
JDM,
With those brackets is there is no need to modify the ones that come with car? Are those for the front and back speakers? How do they fasten to the car? On the pictures that I have seen it looks like the existing bracket just snaps in to place. Do you just screw into the medal with self tapping screws?
Thanks!
Old Sep 15, 2008 | 08:41 PM
They just bolt right in no need to modify anything.... and they come with all of the hardward and stuff you will need to install them.. Also they are universal front and rear are the same.
Old Jan 2, 2009 | 04:08 PM
vwli's Avatar
Nice Post, thanks
Old Jan 2, 2009 | 05:38 PM
chyperX's Avatar
here is a link to diy the factory speakers into brackets, would post article but posting from iphone. It's 2/3rds down the page www. Hondafitblog.com/ hope this helps. Can Someone else copy article across with pictures
Old Jan 3, 2009 | 02:46 AM
rehkopf's Avatar
so just to get this straight, the fronts and the backs need this bracket/trim ring piece to fit? also, how big of a difference is the sound, i was gonna hold off on doing a sub if there's a pretty good difference, i'm the one that has the avic f90bt in the 09
Old Jan 3, 2009 | 12:34 PM
niko3257's Avatar
yes you will need a bracket or you can just cut your
old speakers.
take a look at the link that i posted just like the poster
above. shows you how to cut out the speaker and install
you own.
The Honda Fit Blog
Old Jan 10, 2009 | 02:52 PM
Ichiro's Avatar
2009 Honda Fit speaker
I am planning to put Boston Acoustics Pro60 - Boston Acoustics Pro 6.5" 2-Way Component Speakers to replace the front speaker and use Boston Acoustics SL 65 on the rear. I am using the Facotry Stereo Navi. Would both of these speaker fit?
MTLian
May 7, 2018 03:56 PM
Cordizzle4life
Apr 28, 2017 04:23 PM
tleger88
Apr 11, 2014 02:11 AM
chinkieboy
Dec 26, 2011 07:48 PM
FITment
Dec 28, 2010 10:11 AM
