DIY illuminated cupholder area for 09 Fit
Old Oct 14, 2008 | 11:35 AM
TKZ12NO1's Avatar
I noticed that in my 09 Sport, it's tough to see the cupholder area in the console. I leave for work in the dark and head home in the dark, so I thought it'd be nice to light up that area so I don't drop my coffee or fumble around for the accessory plug and my cell phone charger.
Another trip to Advance Auto supply yielded a $9.88 "LED POD" by OPTX that connects to 12V and shines blue light. I also picked up a purple neon mini tube for $4.98 on clearance that I'll use in my wife's Tidewater 09 base fit.
So here's how I did it...
1) The panel right under the recirc/fresh air control that overhangs the cupholders comes off by prying on it from the bottom edge. Pops right out.
2) I tried to find dash illumination wires right up in there with the A/C controls but did not want to pull too much stuff out, so instead I took off the console.
3) Took the carpet insert out of the rearward most pocket of the console. Unscrew the phillips screw. Took the pop 'ems out of both sides of the front of the console. Took the cover out from in front of the E-brake. The console is held on by a clip somewhere in the area of the gearshift, so I pulled up until it popped out. Then I lifted and turned and moved the gearshift to drive to make it easier. PLEASE, IF YOU DO THIS BE SAFE AND DONT RUN ANYONE OVER, DO IT WITH THE KEY ON BUT ENGINE NOT RUNNING.
4) Once the console was out I found two wires that go to the lights for the gearshift. Both were red with black stripes and silver tracers. One will give constant (+) with lights on. The other, strangely enough, will give variable ground when adjusting the dimmer.
5) Connected the (+) to the lead that is hot with the dash lights on, and the (-) to the lead that is variable with the dimmer. Tested and the LEDs actually dim a bit. Cool!
6) Made some extension wires and ran those up to the area above the cupholders.
7) Saw the reason why my right leg would feel hot while driving in cool weather. There's some duct work in the console for rear passenger heat. This ducting has a feed from the top that sits in the tubes on the bottom that lead to the rear passenger area, but there's no seal at that joint. So I put some electrical tape around that junction to prevent the hot air leaks.
8) Also noticed that we're along side our gas tanks. At least that's what I'm guessing the big metal plate on the tunnel is covering.
9) Put it all back together, and left the LED out as I put back the panel. Velcroed it to the panel and now I have nifty blue light so I can see my Java!
Pics will be added later.
I'm not big on cutting my cars anymore. I used to do all kinds of stuff I'd later regret, so I'm big on velcro, wire ties, and snug fits. I leave the dremel in the workshop.
Eric
Old Oct 14, 2008 | 01:36 PM
Virtual's Avatar
Great post!
Old Oct 15, 2008 | 12:25 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
pics please
Old Oct 15, 2008 | 09:09 PM
TKZ12NO1's Avatar
Well, I think the light I put in is a bit too bright! I'm going to find a way to tone it down. Then I'll take some pics.
Old Oct 17, 2008 | 04:57 PM
broheim's Avatar
We are, in fact, next to our gas tanks....that's how they managed the Magic Seat!
Old Nov 13, 2008 | 08:39 PM
ERyan1189's Avatar
second the pics comment
Old Nov 13, 2008 | 11:29 PM
dirtybird222's Avatar
i need to get off this website, you guys are making me want to do to much to my Fit when I need to be finishing my Trans Am. Good write up. I have a ton of extra LEDs laying around that I would love to mess with but this car is staying as stock as possible with the exception of HIDs.
Old Nov 13, 2008 | 11:35 PM
RedFitBaron's Avatar
Great post. I look forward to pictures.
Old Nov 14, 2008 | 01:18 AM
OhNineFIT's Avatar
Pic Pic Pic Pic Pic Pic Pic ? Thanks
Old Nov 19, 2008 | 08:46 PM
reako's Avatar
I took the liberty of posting his pic from another thread he has going....Such an awesome idea! I really want to do this, possibly a whiter color and not as bright. (personal preference). What type of bulb is it? Link? Thanks!
Old Nov 19, 2008 | 09:52 PM
Stormtrooper's Avatar
couldnt you have just ran some wires to the fuse box and tapped a fuse? just wondering...
Old Nov 20, 2008 | 05:15 PM
kortnie's Avatar
Or just get a brightly lit phone charger for the cigg lighter, and leave it in even when the phone's not charging?
Old Nov 20, 2008 | 08:39 PM
TKZ12NO1's Avatar
I tapped in where I did for the ability to dim the light. The LEDs will dim, only slightly. I'm probably going to put a different light in there, standard type bulb, with a bluish lens, maybe. Something that'll match the color of the dash lights. We'll see.
Old Nov 23, 2008 | 09:32 PM
fitscott's Avatar
Has anybody tried installing the Honda OEM Ambient Light kit in this area? Seems more useful to me to have light on the cup holder than on my feet?!I'm guessing that the LED that goes on the passenger side will work, but I doubt the wires are long enough on the one for the driver's side.
Old Nov 25, 2008 | 08:35 PM
reako's Avatar
Cool idea! I guess you could just splice into the wire and extend it a bit?
Old Feb 23, 2009 | 04:27 PM
anyone find a good fuse# to tap into yet? wife's been
asking me to install a LED over the cupholder in my GE
as i did on my GD.
just kinda lazy to go look for a good fuse. on my GE i
used a fuse that had a delay timer..meaning, it would continue
to illumiate even after removing the key for about 30sec.
rel_90806
Jan 28, 2013 12:10 AM
Toscha
May 5, 2010 10:06 AM
moorefitloving
Sep 20, 2009 01:13 PM
roundworldsobig
Jun 13, 2009 05:48 PM
fitscott
Oct 20, 2008 03:51 PM
