Brake Rotors
Old Aug 4, 2019 | 09:12 PM
Odie's Avatar
Brake Rotors
Are the OEM Honda Brake rotors vented ? This is for a 2013 Fit. Also does anyone know what thickness they start out at ? Thanks
Old Aug 4, 2019 | 11:04 PM
Red 05's Avatar
The originals are 10.3 inch vented rotors. Reasonably cheap rotors. If you want to blow a bit of money look into replacing with Integra Type R calipers and 2008 Min Cooper rotors. Get the 280mm rotors. These are 11 inch but more importantly have much more meat on the brake pads. Direct bolt-on, and apart from needing to bend the dust shield slightly to clear no modifications needed.
mitcho85
Oct 12, 2018 06:32 PM
wxgeek
Dec 27, 2016 07:43 AM
phenoyz
Jun 3, 2014 11:52 PM
lilcat
May 5, 2009 01:00 PM
Nino NoSpam
Aug 11, 2005 09:30 PM
