DIY- Replacing the Water Pump on a '09 Fit
Old Oct 10, 2011 | 03:45 PM
FitCrazy80's Avatar
What's up guys,
So the same female friend who had me change the cam chain on her '09 asked me to help her replace the water pump this past weekend. I think I should start charging her in the near future
Anywhoo, here is the guide that I used to replace the water pump on a '09:
1) Drain the engine coolant.
2) Remove the right front wheel.
3) Remove the splash shield. It's shown as ref #5 below:
*diagram courtesy of hondapartsnow.com; all rights reserved
4) Loosen the water pump pulley mounting bolts.
5) Remove the drive belt.
6) Remove the water pump pulley.
**Shown here: Remove the water pump pulley**
7) Remove the water pump and O-ring by removing the five bolts.
**Shown here: Water pump (A) and O-ring (B)**
8) Inspect and clean the O-ring groove and the mating surface of the engine block.
9) Install the water pump with a new O-ring in the reverse order of removal.
10) Clean up any spilled engine coolant.
11) Install the water pump pulley.
12) Install the drive belt.
13) Tighten the water pump pulley mounting bolts.
14) Install the splash shield.
15) Install the right front wheel.
16) Refill the radiator with engine coolant, and bleed the air from the cooling system with the heater valve open.
Old Oct 10, 2011 | 04:20 PM
Wanderer.'s Avatar
Why'd you have to replace the water pump and cam chain on a 2 year old car? Crazy high mileage?
Thanks for DIY.
Old Oct 14, 2011 | 01:05 AM
john21031's Avatar
Maybe he told her it needs to be done... to be able to charge her for it?
Old Oct 19, 2011 | 09:35 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
Thanks for DIY.
yeah thats def weird.
Old Oct 19, 2011 | 09:59 AM
Schoat333's Avatar
OK, WTF again?
Thanks for the DIY's tho.
Old Feb 10, 2012 | 09:26 PM
Steve244's Avatar
I think some helpful person must've told her all timing belts should be replaced at 60K miles* and to do the water pump at that time. They didn't tell her the difference between a belt and a chain. And that the position of the pump on the Fit means it can easily be done without removing the timing belt-er-chain, so it's not a maintenance item.
Fit's have a heater valve?
*but the last Honda I had with a belt, a '97 4cyl, had 105K intervals on the timing belt.
Old Feb 27, 2013 | 12:16 PM
Jaseun's Avatar
Look, I enjoy wrenching on my car as much as the next guy, but changing a water pump at 60K for 'maintenance' is just silly.
I'm betting this female friend is just looking for excuses to get you to hang out.
Old Feb 27, 2013 | 12:33 PM
Wafulz's Avatar
Ahh Nice im glad i found this im one of those OCD people that will change it sooner then normal lol
Old Feb 27, 2013 | 03:23 PM
Dean's Avatar
Well.. since the OP's Last Activity: 11-09-2011 06:17 PM I am guessing she didn't care for the idea of having to put out for work?
OrangeSport09
Oct 24, 2018 12:15 PM
robcollins5
Mar 11, 2010 01:27 AM
coralaholic
Sep 18, 2009 11:37 PM
wskwong
Nov 19, 2008 06:56 PM
mmdir2005@yahoo.com
Oct 11, 2005 11:36 PM
