Spark Plug Blown on Low Mileage Fit (HONDA DENIES WARRANTY)
Old Aug 16, 2021 | 11:54 AM
  #161
drkazknght's Avatar
Red face +4 year +40k update
So hitting 100k now and 4 years since last incident I started noticing the all-too-familiar gas smell while driving. I went ahead and checked all the spark plugs (which is actually quite easy now with a skinny left arm). 4 years ago I tapped/rethreaded the #2 spark plug but this time it checked out okay. It was the #4 (USA Driver's side) that was loose about 1.5 turns. Kind of bummed a plug loosened but happy it only loosened a bit. Since the car isn't worth too much I may try to put some high temp permanent threadlocker to the spark plugs and I should be good till 200k.
Old Jan 22, 2025 | 11:48 PM
  #162
skidsteer226's Avatar
Originally Posted by eulogy
its not an official fix...but my recommendation has been to treat the plugs like they are one time use. i believe once u crush the washer even at 14 lbs, and or back the plugs out, its done and will never hold again even at higher torques. id say have a set of plugs on standby, and next time you check them and if they are loose just replace all of them and take them to 20 ft lbs. and after that if you "check" them, only turn in the tighten direction with the torque wrench.
i had a couple of loose plugs on my car a year and a half ago. the loosest one was tighter than hand tight, but definitely not at the recommended torque. replaced all of them and have done what i described above and they have been fine.
anyways, keep an eye on em and i hope u get em sorted
20 ft/#s as per the dealer in the updated service manual.
Old Jan 22, 2025 | 11:53 PM
  #163
Originally Posted by spike55_bmw
At 26,000 miles (2011 Sport), my #2 & #3 came loose (#2 first and dealer fix and 2 days later #2 & #3 were bad). Dealer's solution was to charge for a diagnostic, charge for a coil pack (#2 only), charge for labor, and never addressing the loose spark plugs that were again creating misfires within 2 days.
I used the blue Permatex directly on the spark plug threads and I now have 63,000 miles and have had any issues nearly 40,000 miles.
My dealer wanted $310 CDN each for coil pack! Rockauto ended up being my new best friend.
Old Jan 23, 2025 | 05:38 AM
  #164
spike55_bmw's Avatar
No loose plugs in 100k on my 2011 FIT after using some blue Loctite or Permatex and using the 13lb-ft torque.
Kevin Evans
Jun 7, 2017 08:43 PM
Reddogs
May 4, 2016 06:43 PM
JonBoz5099
Mar 26, 2015 11:36 AM
FRAMEshift
Sep 8, 2011 05:06 PM
Gumpster
Honda Fit Dealer Reviews
Oct 16, 2006 04:10 PM
