Rattle from outside triangle trim piece above fender
Old Mar 22, 2013 | 07:02 PM
ciref8's Avatar
I've been getting this constant rattling whenever I hit a bump or play any music with any hint of bass. I found out that its because there is a slight gap between the triangle trim piece above my passenger side fender. My driver side is perfectly snug and does not rattle at all.
How would I go about fixing this?
Old Mar 22, 2013 | 07:39 PM
Wanderer.'s Avatar
I have the same issue on the same side so in for answers.
I figure probably take it apart and replace clips or tighten whatever holds it in.
This is in addition to a window rattle on the same side i've developed. Can't hear it unless the driver's window is down... not sure if it's related or the same thing causing it, really annoying.
Old Mar 23, 2013 | 04:41 AM
Black3sr's Avatar
Manual says to release clip using proper tool at the top then slide back to release a couple of tabs. Maybe a bit of silicone on underside and replace?
Check the piece of cowling in the corner of windshield. That is the piece that usually rattles sounding like it comes from glove box area. Just put a tiny piece of cloth/shop rag under corner solves it.
sschoe2@gmail.com
Sep 20, 2017 11:04 AM
sschoe2@gmail.com
Sep 11, 2017 11:29 AM
zaebra
Aug 23, 2017 02:02 PM
Michael Raymond
Nov 16, 2015 04:12 PM
ciref8
Apr 9, 2013 05:45 PM
