Do i need my air condition refilled?
Old Apr 27, 2013 | 11:53 AM
Vash's Avatar
I remembered on my old mustang when the air condition compressor would cut on and off all the time with the AC on, then it means that its low on coolant.
Is it the same on the honda fit? Is it time that i go get my coolant refilled? Iam at a stop light and i can gear the compressor come in and out. or when iam at the drive thru at some fast food place.
Old Apr 27, 2013 | 04:09 PM
doctordoom's Avatar
Supervillain
No you don't need to add refrigerant. You probably didn't notice it cycling when it was new, it's normal.
You don't lose any refrigerant over time unless there's a leak in the system. And if there's a leak in the system, then you need to repair it and then refill the refrigerant.
Old Apr 28, 2013 | 01:23 AM
loudbang's Avatar
What he said ^^^
Old Apr 28, 2013 | 08:36 PM
Carbuff2's Avatar
The Honda A/C cycles on and off.
The Mustang, probably didn't (it is a different type of control system, once engaged the compressor stays on)
At least, that's the way it was with our former '88 Mustang.
BigSpark
May 7, 2021 03:42 PM
phybere
May 29, 2018 11:46 PM
taxonomy
Jun 17, 2017 10:08 PM
polaski
Jul 31, 2014 01:47 PM
slam101
Sep 16, 2013 11:32 AM
