Can I change the crush washer on the drain plug?
Old Mar 13, 2014 | 09:55 AM
GeneralLee86's Avatar
Question Can I change the crush washer on the drain plug?
I know your suppose to get a new one but was wondering if I could just put a regular washer on there instead? So I won't need to replace it every time I change my oil! That would be nice!
Old Mar 13, 2014 | 11:48 AM
Wanderer.'s Avatar
I wouldn't recommend it. The reason it's a crush washer is it will conform tighter to the drain plug and really seal it. If you just put a regular washer there's a chance it will drip a little I think. That happens if you don't use a washer.
Crush washers are like $.99, or a few bucks for a pack of three. Just do it the right way?
Old Mar 13, 2014 | 02:31 PM
ikutoisahobo's Avatar
I don't see how you're messing it up every oil change. You're most likely not doing it right.
Old Mar 13, 2014 | 03:16 PM
Rampo's Avatar
I would never reuse a crush washer. The reason its called a crush washer is because it crushes when used.
Old Mar 13, 2014 | 03:21 PM
Fit Charlie's Avatar
I had my last car for over 200,000 miles. I reused the crush washer for a few years until I lost it. Never bothered to replace it. No leaks.
Old Mar 13, 2014 | 04:04 PM
Texas Coyote's Avatar
Use a propane torch to heat the washer until it glows. Let it cool and reuse it..
Old Mar 14, 2014 | 08:50 PM
Carbuff2's Avatar
I re-use my crush washers, UNLESS I see a drip.
So, I end up replacing them every 4th or 5th use.
YMMV of course.
PS I always have spares on hand (all sizes used by Honda) just in case...
Old Mar 15, 2014 | 02:59 AM
Goobers's Avatar
I just replaced the drain bolt (and washer) with a "fumoto valve."
There, don't have to worry about buying more or reusing old crush washers.
Old Mar 15, 2014 | 09:56 AM
doctordoom's Avatar
Supervillain
I've replaced the crush washer once in over 100,000 miles. Never had a leak. Just torque it to spec.
JerryHughes
May 16, 2019 12:12 AM
Ogrelode
Mar 12, 2019 02:46 PM
uniguar
Oct 7, 2012 10:08 PM
moolman
Apr 3, 2012 01:20 PM
moates
Nov 11, 2007 06:56 PM
