CEL P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
Old Jun 2, 2014 | 09:52 AM
Jutboy's Avatar
Question CEL P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
Hello All,
Got my first CEL on my 2010 Honda Fit (base/auto). Before I go out and buy a new o2 sensor I had a couple questions for you.
1) Which sensor is this? I'm assuming the rear one?
2) Could this be something else (should I test for other stuff before buying sensor?) I read it could be something to do fuel pressure/injectors/vacuum leaks/exhaust leaks.
3) Should I get a genuine honda part or are there aftermarket ones that are just as good?
4) Any suggestions on where to buy the parts from? I have to get a few other things as well and would like to save money.
Thanks for your help
Old Jun 3, 2014 | 04:22 AM
Carbuff2's Avatar
Get a Denso O2 sensor. The universal sensors are NOT wide-band and the code will come back.
Rock Auto sells these at good prices (but I would reference the number for the Fit on the Denso site to make sure you have the correct one, first)
You need to post the actual code. Usually the first sensor sets a CEL before the second one. The second sensor monitors catalytic converter efficiency, if its a P0420 (and you lived with the misfire/stutter that many Fits experience) your cat-con could be bad.
Old Jun 3, 2014 | 08:38 AM
Jutboy's Avatar
Hey Carbuff,
Thanks for your help. The CEL was in the title : P0139
No noticeable difference driving at all. The light actually went a way a couple times (but always came back).
Old Jun 3, 2014 | 05:18 PM
Carbuff2's Avatar
Originally Posted by Jutboy
Hey Carbuff,
D'Oh! Stop hiding it in plain sight.
I looked here:
OBD-II Trouble Code: P0139 Oxygen Sensor Circuit Slow Response (Bank1, Sensor2)
I've not seen this as a common problem on Fits but it could be a bad or broken sensor wire.
Part number: 36532-RB1-004 Tres Expensive! $121 USD
It's right at the bottom (#14) so it COULD have damaged wires
So it's confirmed, on the Fit it's the lower (post-Cat) sensor.
Rock Auto has NTK (AKA NGK) sensor for ~$63
Denso @ RA is more $$ than than Bernardi @ $147
I'd have a look before purchasing anything, wires can be repaired....
Old Jun 4, 2014 | 08:16 AM
Jutboy's Avatar
Perfect. Thank you so much for your help! I appreciate it.
Old Jul 16, 2022 | 12:00 PM
MagicalSeats's Avatar
Did replacing your downstream oxygen sensor after the catalytic converter fix your problem? Thank you
Hello All,
Old Jul 16, 2022 | 01:06 PM
Jutboy's Avatar
Yes it did
Old Jul 16, 2022 | 01:44 PM
Yes it did
thank you for your reply,
I meant to also ask did your car have any symptoms when it was throwing the code or was it just the code itself? Any stalling or rough idle or delayed pedal response or any symptoms at all that went away after replacing the 02 sensor??
Thanks Again
edit: Oh nvm I guess you said there was no noticeable difference in driving. So there were never any symptoms, but replacing the downstream sensor made the code disappear forever. Huh
Old Apr 12, 2024 | 11:51 AM
michel54's Avatar
I have read in other posts that you should always replace an O2 sensor that matches the one you are Not replacing.
OR replace both of them, and go with Bosch even though it's more $, it's less trouble down the road.
Good luck,
michel
Old Apr 25, 2024 | 12:43 PM
michel54's Avatar
yes it is now fixed. I would highly recommend the Bosch instead of cheaper brands.
Quality counts, ( & it 's not something I enjoyed changing, for sure)
Michel
Old Apr 25, 2024 | 12:45 PM
michel54's Avatar
OBD sensor code PO139
Thanks Again
only got the code, therefore wouldn't pass inspection.
Car ran ok before and after.
Code went away, car's inspected now.
Michel
Old Apr 25, 2024 | 12:46 PM
michel54's Avatar
should say I replaced the O2 downslope sensor w/ a Bosch (quality unit)
Old Apr 25, 2024 | 12:47 PM
michel54's Avatar
Bought mine from Honda of Keene for less than $100.
Quick (relatively) fix.
Old Apr 25, 2024 | 12:49 PM
michel54's Avatar
Thanks Again
Michel
Honda price was close to NAPA parts store price and I was in the area, so.....
Old Apr 25, 2024 | 12:50 PM
michel54's Avatar
Honda part
If you buy the "honda OEM part" you're paying a lot more for the same part.
Old May 16, 2024 | 07:11 AM
michel54's Avatar
sebsir
sorry for trhe late response.....yes it was the rear/lower sensor.
rwjd
Apr 12, 2024 11:54 AM
fitowner10
Mar 9, 2019 09:02 PM
Hirvi
Nov 25, 2011 11:11 PM
leonine
Nov 9, 2006 11:23 AM
