WTH is up with my wipers?
Old Dec 3, 2014 | 10:43 AM
Santiad's Avatar
So yesterday it was raining in NYC, but not much, so I put my wipers on the lowest intermittent setting.....that usually means one wipe every few seconds....
instead my wipers went cray cray, randomly choosing it would go 2, 3, 4 times between breaks, stopping halfway up my windshield, and at one point just going steady as if I had it on the next setting....
any ideas freakers? felt like I was in a sitcom jalopy.
Old Dec 3, 2014 | 02:34 PM
Wanderer.'s Avatar
Sounds like a switch issue, though I haven't seen anyone else with this issue before on here. Could be bad or intermittent contact in the switch would be like switching the wipers on and off even on the slow setting would cause it to wipe more than once.
If that makes any sense.
Old Dec 3, 2014 | 06:17 PM
k-man's Avatar
perfect time to do the variable intermittant wiper switch mod.....
Old Dec 3, 2014 | 08:03 PM
patm95's Avatar
Does it work properly on the other settings?
Old Dec 30, 2014 | 10:22 PM
mugen666's Avatar
My wiper switch started to act weird, too. Wouldn't go on intermittent or normal. Would work on quick wipe and on high. I took the thing apart, cleaned it, put it back together and now it doesnt work at all. Just rear wiper and the spray on both rear and front.
I'm hoping a new switch will fix the problem. Will be ordering one tomorrow.
Old Dec 30, 2014 | 11:46 PM
Santiad's Avatar
fixed....4 now
So I was took out the motor and when I unplugged it, I noticed some water and gunk had gotten between the plugs....blew it out and let it dry...put it together and so far so good.
Old Dec 31, 2014 | 06:53 PM
hogwylde's Avatar
Take the motor out, unplug it and let it dry. Some gunk probably got in it.
Old Dec 31, 2014 | 08:44 PM
mugen666's Avatar
^Yeah, hoping that'll work. It's worth a try. Thanks
Old Jan 11, 2015 | 10:42 PM
mugen666's Avatar
Well, the motor and connector were bone dry and very clean. I did hook up power to the pins of the wiper motor and the low speed did not work. I took the motor assembly apart and found that there was a very deep grove where the contact meets the moving part. I bent the contact over a bit so it didn't sit in the well-worn rut. I put everything back and tested it and it all worked as it should.
What didn't work was the switch on the steering column. I ordered one and as soon as I got it and connected it, everything worked.
In all of Canada, there were only three of these parts. Apparently the switch rarely fails.
Anyway, all is well. The switch was a 30 dollar part.
BTW, if you take the wiper motor apart, make sure you have dielectric grease and Hondabond on hand. There is no gasket between the plastic cover and the rest of the wiper motor. Hence the Hondabond. It looks like the motor comes from the factory with Hondabond, so it was a no brainer.
Old Jan 11, 2015 | 11:42 PM
Santiad's Avatar
so I might try replacing the switch.....
noticed my wipers dont want to work at all now until the car is warmed up or at least 5 minutes of warming up...which makes no sense...I'll submit an update if I get this sorted. This winter has been trying between my grinding starter, wipers, and hatch lever feeling off...
thanks!
Press Fit
Nov 19, 2015 07:41 PM
wingmanz
Oct 10, 2010 05:32 PM
natepartlan
Aug 12, 2009 02:01 PM
Squawking7500
Feb 4, 2009 08:38 AM
gts1985
Jan 14, 2008 01:22 PM
