2014 fit map/dome/rear light fuse location?
Old May 3, 2015 | 09:27 PM
cplus's Avatar
Hi everyone,
just bought a 2014 fit lx, while I was changing the map light bulbs today, I accidentally hit the socket with screwdriver, then all the interior lights went out, tried to check the fuse, but couldn't locate the right one, can someone point it out
thanks in advance.
Old May 3, 2015 | 10:48 PM
Codger01's Avatar
I think # 29 ( small light)
Old May 4, 2015 | 12:33 AM
cplus's Avatar
Thanks, tried that one is fine..
Now just realized the readio and cd player has no power, power door lock won't work when key is off, works when it's turned on, no warning beep when key is in ignition and head lights can not be turned on when car is turn of.
which one control the power when key is off?
Old May 4, 2015 | 04:44 AM
DWils's Avatar
You have a 2014 Fit? Weird. I thought Honda stopped making them in 2013 then picked back up again in 2015. In any event, just pull all the fuses and check them one-by-one until everything works that you want to work.
Old Jun 4, 2015 | 07:58 PM
djcrawf777's Avatar
Same thing
OP, did you ever fix the issue? I'm having the same exact problem. Radio, lights, door locks and remote won't work without the key. Even when the key is in the ACC position nothing.....
Old Jun 4, 2015 | 10:14 PM
cplus's Avatar
Nope, gotta bring it to the dealer when I have time.
Old Jun 4, 2015 | 10:27 PM
djcrawf777's Avatar
Same thing
update.....I finally fixed it. Interior fuse number 1 (Back Up) 10A. Replaced that one and everything is back to normal. At first I though the "back up" meant extra spare fuses but it controls most of the interior accessories. Hope that helps!!! 2013 Honda Fit (Base)
Old Jun 4, 2015 | 11:18 PM
cplus's Avatar
You are the man!
Thanks!
I would never thought "Back Up" has anything to do with this.
Old Jan 15, 2016 | 07:06 PM
TidalWaveOne's Avatar
Thanks! This just really helped me as I had the same issue. I was afraid I was going to have to go to the dealer.
I confirmed the fuse is blown and have to find a replacement fuse (does the car come with any spare fuses? I will do a search to try to find out.) and replace but I am glad to hear this fixes it.
I'll be more careful next time when messing with the map light.
UPDATE: It worked! I replaced the number 1 "Back Up" fuse from some fuses I bought at Walmart and everything started working again but I did have to find and enter the anti-theft radio code. Fortunately the radio remembered my stations but I did have to reset the clock.
Henry Cruz
Mar 4, 2019 02:07 PM
UrAll2ez
Jan 4, 2017 01:33 PM
ChooseMyFate
Dec 5, 2016 11:42 AM
espo79
Jun 30, 2008 03:52 PM
dbcmaster
Apr 11, 2008 02:51 PM
