Engine misfiring?
Old Nov 11, 2015 | 07:46 PM
howardmitch's Avatar
Engine misfiring?
I have a 2008 Honda Fit with 95,000 miles, automatic transmission. When I drive on the highway at approximately 2500 rpms (60 mph) the engine seems to slightly misfire. It does not totally lose power but there is a slight "miss". This does not happen at other rpms only at 2500 rpms. 2500 rpms seems like the place where the auto transmission would shift to another gear. I'm not sure if this is an engine misfire, transmission problem or other. Any help is appreciated. Thanks.
Old Nov 11, 2015 | 08:30 PM
jibberjabbs's Avatar
Spark plugs.
Old Nov 12, 2015 | 09:30 AM
Carbuff2's Avatar
Read the coil/plug/valve Topic "Constant Speed Stutter"
MIS-FIT
Jun 27, 2018 09:57 AM
hondafitty
Jul 9, 2015 08:26 PM
andeano
Feb 26, 2015 04:35 PM
Solscud007
May 13, 2014 01:21 PM
ThePolandball
Oct 1, 2012 07:30 AM
