This is the radio I want to get for my Fit:
It is a Jensen VX6020 and here is a link to where I am buying it from Jensen VX6020 Navigation receiver at Crutchfield.com It has navigation, plays DVD's, CD's, and iPod too. What does anyone else think of it?
You do also have the option of making use of those preouts and buying a 4 channel amp to go with your radio.
Nothing says fuck subwoofers then 4 high quality speakers that are properly amplified
(This is federal law, by the way—it's part of the Magnuson-Moss Warranty Act.)
I ended up changing my mind and buying this in dash navigation, DVD, and satellite radio from Crutchfield.com The Clarion NX602
Clarion NX602 Navigation receiver at Crutchfield.com
do you have to remove the center console in order to get to the e brake wire to attach the green wire from a clarion nx602 so you can watch dvd's because I do not want to do the bypass?
The wires will go back up towards the dash somewhere and, if you knew where, then no you can tap into them. But, you have to know where they go and the color of the wire.
We have enough people here tat have had their consoles out and hopefully one of them can remember.
Here's the bypass I used on my Clarion. It connects at the radio with no need to splice into the car's wiring.
I just did all the wiring and crimping for the receiver harness to the adapter harness and I noticed that the black negative from the receiver has hook on it can I still cut it and hook it to the chassis ground on the adapter or does it have to be to it's own ground?
yellow wolf
Oct 24, 2015 05:51 PM
Crawly
May 9, 2008 11:17 PM
