Replace Steering Wheel to FD2R Streering Wheel
Hi
My steering wheel has been torn at 2 spots because of steering lock. I am thinking to replace with FD2R steering wheel. However, my steering wheel has volume and auto cruise buttons. Can it be transferred to FD2R steering wheel? Any modification need to be done?
I swapped to a FD steering wheel just fine. The civic buttons are wired differently to the spiral assy so I just swapped the jazz/fit buttons to the civic wheel. My stock wheel was the basic round type. The new civic wheel diameter is smaller and more sporty.
Hi,
Is the steering wheel on this picture above came from what you said as
"the new civic wheel that is smaller and more sporty"?
May I know from what year did the steering wheel on the picture above came from?
and
if you know the exact part number, that is even better.
I am really interested.
Thanks
and
Thanks
Hi,
and
Thanks
and
Thanks
The civic steering wheels in aus are all like the above (smaller OD vs the jazz).
hey dumb question, but is there a writeup on how to remove the steering wheel?
I have a base and picked up a sport wheel because I felt it was easier and cheaper than buying the leather wrap kit. From what I can guesstimate, you need to pull the negative cable for the battery and wait a while, and there are two bolts on opposing sides to remove the airbag (anyone know what size they are??). Am I missing anything??
When disconnecting battery I press the brake pedal a few times till the pedal is hard to press. Then wait a few minutes to make sure. Good luck!
https://www.fitfreak.net/forums/2nd-...-controls.html
Sorry I wasn't clear, the two photos are of the same civic steering wheel. I just swapped the buttons and stitched a leather cover to it in the second photo. The wheel is from a 2007 FD civic. Sorry I don't have part numbers (bought used).
May I know where did you bought the Leather Cover for this Steering Wheel?
Thanks
I got it from Aliexpress and chose the red stitch option:
Steering Wheel Cover for Honda Civic 2004-2011 XuJi Car Special Hand-stitched Black Leather Covers
http://www.aliexpress.com/item/Steering-Wheel-Cover-for-Honda-Civic-2004-2011-XuJi-Car-Special-Hand-stitched-Black-Genuine-Leather/2038160516.html?tracelog=ae-app-ios-sharefor-shkmail
Sent from AliExpress
There is another seller with more colour options red black blue yellow grey:
Black Leather Steering Wheel Cover for Honda Civic Old Civic 2004-2011
http://www.aliexpress.com/item/Black-Leather-Steering-Wheel-Cover-for-Honda-Civic-Old-Civic-2004-2011/32253849141.html
blingers,
could you use the black plastic on the steering wheel from the FN instead of the silver from the jazz?
Did you use the ge8 airbag on the FD too?
i am thinking about swapping my GE8 with either an FD wheel or maybe an FN2R.
zeniitti
Aug 31, 2017 03:34 AM
thanks
