misFIT.
Old Aug 4, 2010 | 12:04 AM
  #141
FitDEEZ's Avatar
Looks. Great and 17s are perfect in GEs I love them in mine
Old Aug 4, 2010 | 12:26 AM
  #142
Gbaby2089's Avatar
wait i thought bigger lip = lower offset?
Old Aug 4, 2010 | 01:04 AM
  #143
danielg's Avatar
Yes you are right, adding an inch of lip reduces offset by 25, I was thinking in the negatives (+0 to -25) my fault.
If your lips are 2 and 3 inch, the math is wrong at +38 or +25 offset.
Based on those offsets;
2" outer on a 9" wide wheel would mean that the front was a x8 +53 (actually, that could be possible, but I don't recall a x8 +53 RS? Could be possible tho)
3" outer on a 10" wide wheel would mean x8 +75 (no way) or x8.5 +62 (no way)
Based on what you said and the way it looks, my best guess is the wheels are near +20 in the front and for sure around 0 or negative in the rear. Although I couldn't tell u exactly unless I knew the original specs to begin with. If you look under the center caps, the size and offset are stamped. If you can post, I'll let you know for sure. I'd love to see how far off I am.
Regardless, it's badass!
Old Aug 4, 2010 | 11:35 AM
  #144
Fit4Trav's Avatar
Show Off
QFT
Old Aug 4, 2010 | 11:57 AM
  #145
FitDEEZ's Avatar
I don't have a lip but my wheels are mild low offset there +32
Old Aug 5, 2010 | 01:11 PM
  #146
R@ymun2's Avatar
I love the color combination...
Old Aug 5, 2010 | 04:26 PM
  #147
illest_GE8's Avatar
Debo'ed Avatar FTW!!1!1!
you have the sickest ge8 i have every seen
ive fallin in love with ur car
ur my inspiration
hope to make mines look like that soon
Old Aug 6, 2010 | 12:30 AM
  #148
misFIT.'s Avatar
Originally Posted by Fit4Trav
QFT
thanks bro.
thanks man, i see you got the orange and blue going
ur my inspiration
haha, thanks man, its an honor to be an inspiration to others. all i can say is that dont listen to the doubters and haters, cuz there WILL BE
Old Aug 6, 2010 | 12:35 AM
  #149
misFIT.'s Avatar
haha
i was just thinking......
all this love and you guys havent seen the interior yet
Old Aug 6, 2010 | 05:24 AM
  #150
fitfreak2's Avatar
ohh shiet haah
Old Aug 6, 2010 | 09:17 AM
  #151
chinkyy's Avatar
wow. sick rims!!!
Old Aug 16, 2010 | 06:01 PM
  #152
slp950's Avatar
Fit looks good! mucho props on making the fitment work, however crazy it may be. Couple of quick questions:
How far down are the coilovers adjusted? Are they at full drop or can they go lower?
And what size and brand tires are you using on the BBS wheels?
Old Aug 16, 2010 | 10:25 PM
  #153
misFIT.'s Avatar
thanks man!
the fronts are maxed out, dropped to the lowest point, and im trying to go lower
the rears still have about an inch to go.
as far as tires are concerned, im using 215/35 Yokohama S. Drives in the front and 215/40 nankang's in the rear (forgot what model they were)
Old Aug 16, 2010 | 11:20 PM
  #154
MugenAP2's Avatar
Old Aug 16, 2010 | 11:26 PM
  #155
Java^FiT's Avatar
Are you sure about this? I was pretty sure that offset was relative to the center line of the wheel and where the hub is. Therefor the extra width of the wheel itself being 9 and 10" incorporates the lip into that and in the process is able to keep the offset close to standard around 30 or 40. granted these are big lips and have offsets closer to 0 but its definitely not negative or above 50.
At least thats what I got out of Tirerack's offset guide. Just my $.02
I could be wrong
Old Aug 17, 2010 | 11:45 AM
  #156
SpoonFitGD3's Avatar
Super Fit car........I like color.
Old Aug 17, 2010 | 10:47 PM
  #157
danielg's Avatar
I could be wrong
You got the idea of offset down...
What you have to take into consideration is that if you just add lips, you're only adding to the outer rim half. If you add one inch of width to the outers, you're pushing the center in 25 mm. If you add an inch to the inners, you're pushing the center out by 25mm.
Assuming that the left side of this post is out, and right side is in. Let's use this example of a 0 offset with inners and outers matching in width.
Normal = 0 offset, 4 inch outer, 4 inch inner
I-I-I
1" Bigger Outers = -25 offset, 5 inch outer, 4 inch inner
I--I-I
1" Bigger Inners = +25 offset, 4 inch outer, 5 inch inner
I-I--I
Hopefully that help some of you out. Donations are welcomed
/end threadjack
MOAR PICS!
Old Aug 17, 2010 | 10:52 PM
  #158
danielg's Avatar
Originally Posted by misFIT.
thanks man!
You're on D2's right? I think I read that. The strut mount is threaded, so that in combination with the adjustable spring perch should get you lower. When I first installed mine, we were literally 2" between the frame and and ground. You can get lower for sure!
If you want to buy my air, LMK - it will help with all that rub when you get lower
Old Aug 18, 2010 | 01:54 AM
  #159
Fit4Trav's Avatar
What's this talk about air???
Old Aug 22, 2010 | 09:48 PM
  #160
misFIT.'s Avatar
Originally Posted by MugenAP2
whooaa! havent seen that one yet lol
were you at hellaflush 6? or did you just happen to find the pic?
thanks man!
did you say air?
im actually VERY interested in air!
static is lovely and all but its just not enough low for me anymore
