FITEVO's Progress Thread: Watch my fit evolve...
Old Oct 9, 2010 | 03:06 AM
  #41
fitevo's Avatar
Originally Posted by blackndecker
BTW, ET35 will look like ass and require spacers unless you like your wheels recessed into the fender wells....
Actually the lower the offset, the more it will bring the wheel to the fender.
Old Oct 9, 2010 | 03:14 AM
  #42
fitevo's Avatar
Installed the LED rear license plate lights
Installing the foglights & headlight bulbs tomorrow
-Frank
Old Oct 9, 2010 | 08:43 AM
  #43
blackndecker's Avatar
You're right...I was confusing myself late last night. I'm not sure if anyone has successfully pulled off that offset on a lowered GE.
Old Oct 9, 2010 | 01:53 PM
  #44
Slowbros's Avatar
FitDEEZ is running a +32 iirc
Old Oct 9, 2010 | 06:30 PM
  #45
fitevo's Avatar
Update:
Installed the GP Thunder Headlight & Foglight Bulbs. What do you think?
Old Oct 9, 2010 | 06:37 PM
  #46
shad2fast4u's Avatar
damn the blue headlight bulbs looks great, hows the visibility on the road?
Old Oct 9, 2010 | 07:14 PM
  #47
fitevo's Avatar
I'll report back on the visibility! But definitely the bulbs do their job!
Old Oct 9, 2010 | 07:41 PM
  #48
hayden's Avatar
So, the license plate leds are those GT thunder ones? They look nice. Taking pics of leds is tricky, but they seem more white than average. I've gone through a few to find the right brightness/hue.
Old Oct 9, 2010 | 07:51 PM
  #49
pics of the road while the bulbs are on would be great
Old Oct 9, 2010 | 09:03 PM
  #50
fitevo's Avatar
The LEDs are from X5 Lighting which is through the same company that I got the GP Thunders from.
They work great!
Old Oct 10, 2010 | 12:06 AM
  #51
More importantly, how's the visibility of oncoming traffic? Retrofit out of respect for oncoming traffic
Old Oct 10, 2010 | 03:47 AM
  #52
fitevo's Avatar
Hey guys,
Just got back from driving around town at night, there is not a loss in visibility at all from the stock headlight bulbs. Still can see oncoming traffic too.
Here are just pics I took with my phone:
Old Oct 11, 2010 | 03:16 AM
  #53
ghettoboy247's Avatar
17x10 0 offset SSR MS1-R SBC (super black chrome) slammed with BC N+, comfortable enough for daily,touge, and Time Attack. It's all in the tuning
Old Oct 11, 2010 | 11:43 AM
  #54
Tuning what? Are you boosted? My limited understanding is that even the Kraftwerks kit isn't tunable on the GD...
BTW pics would be nice...I'd like to see 10" width with 0 offset on a Fit. What size tire are you running? TBH, I really don't see the point of 10" wide wheels if you're not boosted...I'd say from my own autoX experience that the Fit is more power limited than it is traction limited (although LSD would be a nice mod).
Old Oct 11, 2010 | 04:42 PM
  #55
fitevo's Avatar
Alright I think I'm going to place an order for my BuddyClub N+ and RPF1s pretty soon here. I'm thinking about taking the risk and trying to fit a 16x7.0 ET35mm on it. I think I can pull it off with some fender roll, stretched tires, and negative camber. What do you guys think?
Old Oct 11, 2010 | 05:04 PM
  #56
I think you could easily pull it off with just fender rolling...maybe slight pulling in the front. I think the rears will come out perfect with no rolling necessary. It's only 7 mm difference b/w these and ET42.
Old Oct 12, 2010 | 02:13 AM
  #57
fitevo's Avatar
I was thinking about going +35mm in the rear while going +43 in the front. What tires should I go with? 205/45/16?
Old Oct 12, 2010 | 02:35 AM
  #58
Personally, I'd recommend going with a 50 series sidewall whether it be 205 or 195/50/16...this will fill out the wheel wells as well as provide some cushion on rough roads. The Fit has a stiff chassis and stiff lowering springs bring out all the bumps in the road. IMHO, 205 tread width really isn't going to do much but add weight and rolling resistance. The Fit only puts down around 95 whp in stock trim...anything you can do to offload the engine will result in a more enjoyable ride.
The staggered wheel set up is going to be a PITA when you need to start rotating your tires.
Old Oct 12, 2010 | 10:28 AM
  #59
hayden's Avatar
I sure as heck wouldn't go with two wheel sizes for only an 8mm offset split. Totally not worth it. Hopefully some spacers are being used instead.
205/50/16s or 195/50/16s (the 195s are not plentiful.)
You could do the low profile 16s if slammed, otherwise I think it looks a little bit odd. With our highway gearing, I'd be shooting for larger rolling diameter anyways. For all out performance, the weight difference is actually pretty significant with a shorter tire due to there simply being more weight farther away from the axis with a taller tire, so that is all something to be considered.
I saw a JDM fit that was sl-am-med on lightweight low-pro 15s and it was incredible looking Seeing if I can dig up the photo. Need to start saving these when I run across them.
Old Oct 12, 2010 | 12:27 PM
  #60
fitevo's Avatar
So what you guys are saying is....get 16x7 +43mm and use spacers to bring the wheels out for a flush look?
