Project Mad Panda - My 2010 Taffeta White GE8 Build
Old Feb 26, 2015 | 04:14 AM
  #281
jdmj0's Avatar
I just... I can't. So J.
Old Feb 26, 2015 | 12:18 PM
  #282
Waiz's Avatar
Avid FitFreak Poster
Will have them installed soon
Old Feb 26, 2015 | 02:41 PM
  #283
j1nNju1c3's Avatar
Originally Posted by Waiz
I will have my Centric rotors and Hawk for sale once I get these installed. Will get you a good deal on them if you want
Less than a year on the rotors and maybe 7,000 total miles driven on them
They also offer them in black but I sprang for the red!
I need new rotors...or semi-used. Ahem Ahem
Old Feb 26, 2015 | 05:56 PM
  #284
Waiz's Avatar
I will hold them for you, you want my Hawk pads too? I will give you a good deal for both
Old Feb 26, 2015 | 06:36 PM
  #285
555sexydrive's Avatar
What are the specs on your wheels? If I remember correctly the TypeF's are 16x6.5+45, it should clear.
Old Feb 26, 2015 | 06:57 PM
  #286
Waiz's Avatar
16x7 +42, I agree it should clear but I always like to anticipate a fix for any issues. I can always run a small spacer but I think it should be fine.
Old Feb 26, 2015 | 07:18 PM
  #287
Ohhh if 16x7+42, zero issues. My front brakes utilize a 294mm rotor up from the stock 262mm and this is exactly the size I need to run to clear. I bought this size for my winter wheel (TR Type C or whatever they are called), but I do need to use a spacer for them only because the spokes are RIDICULOUSLY FAT!!! The TypeFs do not have fat spokes so you should have huge amounts of space for clearance. On the CEs, I have 8mm of clearance to the spokes. Haven't measured with the RZs yet.
Old Feb 26, 2015 | 08:19 PM
  #288
Waiz's Avatar
Now one thing I just thought about is whether they clear the spare tire. I might need to buy a spacer and leave it in the car if not
Old Feb 26, 2015 | 08:52 PM
  #289
Or just get the punc kit, that is how the Fits were released here in Japan. No spare tire, just a temporary fill kit. Less weight to lug around and lasts as long, unless of course your tire gets slashed versus just a puncture, punc kit not going to help at all.
Old Feb 26, 2015 | 10:52 PM
  #290
Waiz's Avatar
Excellent idea, ordered a kit for both cars.
I have seen that most new cars no longer have a spare and was curious to see what they use. I ended up getting a kit that combines an inflator and the sealant after doing some research. Will be nice to have that added weight removed
Old Feb 26, 2015 | 11:12 PM
  #291
Good job. The inflator is nice as well at events, you can adjust air pressure easily.
Old Feb 27, 2015 | 12:15 AM
  #292
Waiz's Avatar
Definitely comes in handy to have the inflator in the car, most of the punctures I have ever had have been small nails which this kit would be fine for.
Old Feb 27, 2015 | 11:32 AM
  #293
j1nNju1c3's Avatar
What kind of deal? You may just sway me with the right numbers
Old Feb 27, 2015 | 03:28 PM
  #294
Waiz's Avatar
PM'd you Jan
Old Mar 7, 2015 | 04:40 PM
  #295
Waiz's Avatar
Teaser
Wilwoods were installed without an issue, wheels have plenty of caliper clearance
Old Mar 7, 2015 | 07:35 PM
  #296
Burzpaw's Avatar
FitFreak Community Team
Teaser
SEXY! I need some Lakewoods on mine lol jk. Must be nice Wais!
Old Mar 8, 2015 | 06:52 AM
  #297
Yummy yummy!
Old Mar 11, 2015 | 03:55 AM
  #298
kollunz's Avatar
How are those Koni struts working out for you? I'm considering swapping my stock ones for those along with swift springs in the near future.
Old Mar 11, 2015 | 04:20 PM
  #299
FittinglyFittedFit's Avatar
Teaser
How does the new brakes feel Waiz? I assume it is going to be night and day difference vs oem.
I will be upgrading brakes soon but unsure what is needed for daily with a little bit of mountain runs here and there.
Waiting to hear your feedback on the new brake setup!
Old Mar 11, 2015 | 06:22 PM
  #300
A good pad and tires that will let the pad do its job. In reality, that is all that is really needed. For almost 5 years I beat on mine with the stock calipers, used PMu HC+ pads and Dixcel rotors all around and I never felt as though braking was bad, never had fade or wished I had more braking prowess. I've only had the new brakes out once on Suzuka and I need to recalibrate my braking because it is so improved. They now scrub so much speed so quickly that it was detrimental more than helpful, so if you're just doing some mountain passes, save your money on the new calipers and put that towards proper rubber and pads that like to bite down hard.
