Under Brace GE8
Old Oct 4, 2013 | 05:00 PM
j's_fit's Avatar
Under Brace GE8
Just want to share....
Sorry for the poor pix quailty....too much noise
Ill take better ones next time!
if you guys are wondering what brand those braces are, here are the list!
KMR 4 Point Mid-Chassis Ladder Brace
KMR 2 Point Mid-Chassis Tie Bar
KMR Rear Sway Bar Reinforcement Brace
T1R Lower Arm Bar
T1R Lower Subframe Bar (Front)
Old Oct 4, 2013 | 05:31 PM
Wanderer.'s Avatar
How do you feel about these braces and why should I purchase said braces?
Thanks for pics!
Old Oct 4, 2013 | 08:39 PM
13fit's Avatar
braces will only be truly effective once suspension is replaced with good quality aftermarket.
I however, do own the rear shock tower brace and I noticed a difference. Mostly because it mounts directly to the shocks themselves.
a Rear sway bar will get a bit of necessity for braces.
Old Oct 4, 2013 | 10:01 PM
j's_fit's Avatar
Rear sway is good stuff.....highly recommend
if I have the money i would do the front too!!
as for the rest of the brace do I feel any difference?
yes and no
basically it just stiffen your chassis don't think they will help with handling...(correct me if I am wrong)
Since I am running Apexi coilovers using the hardest settings
i am guessing without those brace my car might just fall apart!!! hahaha
I am still saving $$ for the Cusco front and rear upper bar and also front sway bar!!!
and of course wheels and tires
oh one more thing....it looks cool hahahah
Old Oct 5, 2013 | 01:04 AM
xxryu139xx's Avatar
do u put it up on a hydraulic lift all the time to admire it? just saying...
Old Oct 5, 2013 | 02:49 AM
kylerwho's Avatar
spoon fed
all these ladder bars that are being designed are getting rather ridiculous. Due to the hatch design a simple solid x bar running through the car will stiffen up far more than braces under the unibody. (thinking in terms of leverage at least)
do you seem to scrape the ground more often now than you did prior to install?
Old Oct 5, 2013 | 08:52 AM
13fit's Avatar
you can see where he scraped while driving.
Old Oct 5, 2013 | 07:06 PM
Huy Bui's Avatar
the GE8 is pretty stiff. only instances where you see a difference is with soft cars. on cars that are already stiff like the STI and EVO, there was no improvement in lap times with these braces.
Old Oct 5, 2013 | 08:46 PM
13fit's Avatar
GE8 isnt that stiff. Its definitely stiffer then the GD platform it replaced, but overall still a soft car.
Nothing a big rear X brace and coilover magic cant fix!
Old Oct 14, 2013 | 01:33 AM
2010FitSport's Avatar
Do you happen to know how much each brace weighs?
Just curious how much weight was added.
Old Oct 14, 2013 | 03:09 AM
j's_fit's Avatar
sorry no idea about the weight
Old Oct 14, 2013 | 06:32 PM
I was just curious.
If it takes 50-60 lbs of metal braces/hardware to corner better would you be close to where you started because your heavier and acceleration is less out of the corners with a now heavier vehicle?
Modifications often come with a trade somewhere.
Im wondering if yo have noticed the handling getting better as you have added the bars over time? Would you recommend all of them? Have you ever taken any off and tested with just some of them on? Which one seemed to have the best improvement?
Old Oct 15, 2013 | 03:11 AM
j's_fit's Avatar
the rear sway is the heaviest!
i think you will not feel any difference in handling with only installing the brace!!
i think is kinda like a combo thingy!! coilover plus braces
if u install the rear sway u will definitely feel the different!!
correct me if i wrong guys
Old Oct 15, 2013 | 08:47 PM
13fit's Avatar
If you buy and install every available brace and sway bar, you will be UNDER 25 pounds added.
dunno where you got that 50-60 punds.
Though such a number is possible if you create a rollcage.
But then the added safety and stiffness FAR outweights the negatives of added weight!!
Old Oct 16, 2013 | 12:30 AM
The 50-60 lbs was a wild guess since I have never handled the bars and wasnt sure how thick they were. The 25 lbs isnt that much. Sounds like its worth it.
steezo_
Aug 28, 2017 12:28 PM
kevinkidstar138
May 13, 2011 10:29 AM
j's_fit
Jan 22, 2011 05:22 PM
mrDFWmechanic
Oct 10, 2009 07:52 AM
F'it_ImFromTx
Sep 1, 2008 10:31 PM
