GE8 Lowered Thread - Post your pics!!!
Old Feb 2, 2011 | 12:24 PM
  #801
FitDEEZ's Avatar
The rear can hold wider wheel there is more clearence naturally
Old Mar 3, 2011 | 01:36 AM
  #802
Goobers's Avatar
Originally Posted by TGIJoseph
not exactly. with the ge's, they're made with a solid rear axle. the rear will not have any natural camber after lowering it so the wheels wont tuck as easy as being said. if anything the front will clear more than the rear.
I thought a solid rear axle is literally the wheels are on an axle shaft. I imagine there's a slight 'camber' effect when one side gets pushed up.
But, our (GE) rears are torsion beams (some folks call it 'H' beam). When one side gets pushed up, there's no camber effect.
Old Mar 3, 2011 | 02:48 AM
  #803
ThEvil0nE's Avatar
^ this holds true
Went out earlier to get some 5mm KYO-EI slip-on spacers for the rear and I took pictures before having the spacers installed...
front vs rear (17x7 +47 | 195/45R17) also notice the nice tiny little stretch on the tires
VS.
even at a distance, you can actually see and notice the difference
and just to add... being that I have 17x7 +47 offset, 195/45 and is now running 5mm spacer at the rear... I can pretty much say that a wheel with 17x7 +42 offset and 195/45 tires will clear easy. You can then just make your calculations basing on those numbers on what offset would clear a 205, 215, 225 tires. BTW, the GE8 has factory rolled fenders.
I will update with pictures of the rear which is now has a 17x7 +42(courtesy of the 5mm spacer)
Old Mar 3, 2011 | 08:48 AM
  #804
WhiskeySix's Avatar
looking forward to it! (I was wondering about this myself.)
Old Mar 3, 2011 | 10:19 AM
  #805
ThEvil0nE's Avatar
I will post pictures from the show...
also...
FitFreaks I need your help & support!!!
My fit was invited to the Tuner Galleria & Chicago World of Wheels this Saturday March 5 2011 and would like your support...
PLEASE VOTE FOR ME!!!
E G M's 2010 HONDA GE8 on Tuner Galleria
My FIT may not be as show worthy as anything out there but I'm hoping for it to be well represented and would be taken notice of with your help.
EVENT LINK: Events & Schedule - Tuner Galleria
Thank you FitFreaks!!!
Old Mar 3, 2011 | 11:00 AM
  #806
Java^FiT's Avatar
also...
Put my vote in, good luck!
Old Mar 3, 2011 | 01:49 PM
  #807
ThEvil0nE's Avatar
^^ thanks!!!
more votes more chances
Old Mar 4, 2011 | 01:00 AM
  #808
ThEvil0nE's Avatar
here... compare to the pic above without the rear spacer (sorry for the very crappy cellphone pics)
rear +42 offset (+47 & 5mm spacer)
+42 rear & +47 front
Old Mar 6, 2011 | 12:32 AM
  #809
DizzleDj's Avatar
loking good
Old Mar 6, 2011 | 12:57 AM
  #810
Iamnotkento's Avatar
before lowering
after
Old Mar 6, 2011 | 05:26 PM
  #811
Mitch529's Avatar
On T1R-S Coils
Old Mar 6, 2011 | 08:29 PM
  #812
07FitSBOM's Avatar
Originally Posted by Iamnotkento
before lowering
after
Hey what springs are you lowered on?
Old Mar 7, 2011 | 09:34 PM
  #813
j1napa0's Avatar
thanks. its currently on function/form type 2's maxed all the way down with 2 perches taken off on all 4 corners. the car has been resprayed to the Basque Red Pearl off the new accords.
wow... thats a nice looking clean Fit there...
Old Mar 7, 2011 | 10:29 PM
  #814
SSMTEN's Avatar
hi.
I hate to quote again, but this so effing hot. That color looks awesome on this car. Wheels look great. Drop is right on. May even be one of my favorite GEs on the forum.
Old Mar 8, 2011 | 03:39 PM
  #815
j1nNju1c3's Avatar
Quick question guys: I want to add an 8mm spacer on the rears, my question is, would I need longer studs? I've heard that 5mm is fine on the stock studs and with 10mm, one would need longer studs, how about 8mm?
My cars lowered on T1R-S springs and have aftermarket rims 16x7+40.
Old Mar 8, 2011 | 03:50 PM
  #816
Vanct's Avatar
^ I was wondering this as well. I don't want to be putting too much stress on the studs. I heard that if you can at least make 3 full turns with the lug nut, it should be ok, but to me that already seems risky.
Old Mar 9, 2011 | 10:23 PM
  #817
jdmjunkie561's Avatar
hi.
Damn I Wang my wing like this!!!!!! What do i need to doo????
Old Mar 9, 2011 | 10:30 PM
  #818
angryfit's Avatar
Lol @ you wang your wing hahahahahahahaha I love the color though
Old Mar 11, 2011 | 06:37 AM
  #819
90 DGRZ's Avatar
3 turns is nowhere NEAR safe when you're holding down 80-90 ft lbs of torque. typically 7-ish turns is safe, i run a 5 mil out back and that alone only gives me 5-6 turns. with an 8 you'll be cutting it close, just go to autozone and dig out 8 replacement studs at 12x1.50 a few mm longer, smack the existing ones out (easy as pie) and throw the new studs on. voila!
Old Mar 11, 2011 | 07:08 AM
  #820
tanabe df210 springs.
