Problem with Progress rear sway bar - bolts pushing up on the rubber seat
Old Mar 11, 2010 | 04:02 PM
xm8's Avatar
xm8
I have researched the Progress rear sway bar and there is a problem with the way the Progress rear sway bar bolts up to the car.
I found a thread that had this information: After installing the Progress rear sway bar, the springs used to sit perfect in the rubber seat on the perch, now there are 3 bolts that are clearly in the way. The rubber seat on the perch is slightly covering part of the holes that the sway bar bolts through. The rubber seat now sits crooked on 3 bolt heads.
Link to picture:
http://lh6.ggpht.com/iiez02/RpxMp6ri...0/P7160029.JPG
Link to picture with some one who used hex bolts:
http://www.daemione.com/fit/progressswaymount03.JPG
http://www.daemione.com/fit/progressswaymount02.JPG
Link to thread with all this information:
https://www.fitfreak.net/forums/fit-...ge-5-a-34.html
Does the Ultra Racing rear sway bar bolt up the same way and does it have the same problem with the bolts pushing up on the rubber seat?
Does the Ultra Racing rear sway bar's 4 bolts mean it is not secured as tight to the car since the Progress rear sway bar is secured by 6 bolts?
Old Mar 11, 2010 | 04:22 PM
secondspassed's Avatar
You can use different bolts that don't stick up so much, this has been discussed a lot for the GD Progress sway bar.
Old Mar 11, 2010 | 04:40 PM
xm8's Avatar
xm8
But even shallow bolts will push up on the rubber seat.
Do you have a link to the shallow bolts and are they grade 8 bolts?
Here's a picture of different bolts and it still sticks up:
Does the Ultra Racing rear sway bar have this problem?
I would rather buy a rear sway bar that works out of the box.
Old Mar 12, 2010 | 01:30 AM
feared's Avatar
the pics you have links to are the bolts provided by progress, not what others have used. as secondspassed has stated, there has been plenty of discussion about the hardware already. progress has changed that for the ge8 from my understanding
and it wont affect performance as long as the springs arent physically on the bolts. it may puncture the rubber spring seat, but it wont affect it performance wise.
Old Mar 12, 2010 | 01:43 AM
xm8's Avatar
xm8
Does anyone have pictures of the new upgraded Progress bolts?
Old Mar 12, 2010 | 04:22 AM
feared's Avatar
Old Mar 12, 2010 | 03:35 PM
Daemione's Avatar
That's my picture - and it's of the original progress supplied bolts, not the replacement button head ones.
Old Mar 13, 2010 | 12:29 AM
xm8's Avatar
xm8
But the button head bolt still push up on the rubber seat.
steezo_
Jan 23, 2018 05:34 PM
xm8
Aug 8, 2010 05:18 AM
xm8
Mar 13, 2010 01:36 AM
dbcmaster
Aug 15, 2008 10:11 AM
ldweng
Oct 8, 2007 03:41 AM
