Drum to disk conversion
Old Sep 11, 2010 | 08:53 AM
SleepyJonDu's Avatar
ok, so i have done the search and everything, all i found is that there were a couple people that said they would have it done soon. so my question is did anybody actually do it?
if you have done it, how much did it cost? how/where did you get the parts?
now i read all the things in a couple different threads that say that disks aren't needed, but i just want to increase braking all the way around, not just the fronts. to that end i would also like to hear about any front brake replacements that anybody has done. i really like brembo because they are a big, established company, but they don't have anything they say will work for the fit. has anybody used any of their brakes as replacements on the fit?
Old Sep 11, 2010 | 11:17 AM
Farther's Avatar
Maybe a big brake kit for the front and then move your fronts to the rear.
Old Sep 11, 2010 | 11:26 AM
bmxman's Avatar
BBK's and rear disk upgrades are a touchy subjects here on FitFreak...be prepared to get bombarded with "why" do you need them or you will get ignored
Old Sep 11, 2010 | 12:07 PM
Occam's Avatar
Random, slightly off-topic question, but the reason I'd always heard for manufacturers switching to rear discs was because drums couldn't be fit with ABS - the drums weren't able to be engaged and disengaged at a fast enough clip to support ABS.
Has this changed? Are modern disc/drum cars able to work around this, and still have 4 wheel ABS?
(sometimes I wish that, like a motorcycle, you could feel the difference in front and rear braking independently. On my bike, the rear does next to nothing for stopping, though it's nice to add some stability at low speeds)
Old Sep 11, 2010 | 12:53 PM
as far as i can tell, the rears also have ABS, but again, it is hard to tell b/c we aren't on motorcycles...
that is a good idea, hadn't thought of that...
and just for anybody who cares, i want to do this because i was going 60ish and a lady pulled out in front of me and stopped, so i'm on my horn and slamming on the brakes and she just stays there completely blocking my lane. i ended up stopping literally inches from t-boning her...in the latest issue of C&D, they tested the Fit, Fiesta, and Mazda2, respectively they took 197, 181, and 183 feet to stop from 70mph, the fit is simply behind and i want it to equal if not better the other two.
Old Sep 11, 2010 | 09:22 PM
bmxman's Avatar
more info here..
https://www.fitfreak.net/forums/2nd-...brake-kit.html
EDIT: on a side note a big brake kit and rear disks would not have helped you in the above situation. Sounds like your issue is traction. Try looking into better tires and pads. It cost less and you will notice a huge difference.
Old Sep 11, 2010 | 11:26 PM
gohdunlam's Avatar
Originally Posted by bmxman
more info here..
+1 tires and pads is what you want to look into upgrading, probably SS brake lines too...BBK is more for track where you need the extra surface area for cooling
Old Sep 12, 2010 | 10:45 AM
ya, ill wait untill i get better tires, then after putting in pads and ss brake lines, i will think about it more.
on another note, some one said in the thread above that for brakes, GE=GD=GE=GD, so would i be able to, if i start to go to the track, put a GD brake kit on my GE, do i only have to worry about bolt patterns(same, right?), or is there something else?
Old Sep 12, 2010 | 10:35 PM
nealy's Avatar
I was looking into doing this, but just havn't gotten around to doing it yet.
Old Oct 11, 2010 | 02:45 AM
ghettoboy247's Avatar
GD and GE is not the same brake bracket. i have jbt mini 6-pot/4pc rotor for sale for GE, rotora 13in bbk for sale and stoptech bbk for sale. if interested, hit me up; ghettoboy247@gmail.com
Old Oct 16, 2010 | 03:39 AM
xm8's Avatar
xm8
I have been researching this subject. To me, drums are shit.
fastbrakes.com has a kit for $975. It's too expensive so I emailed them.
fastbrakes informed me that they can sell me:
bracket kit, park brake cables, brake lines and plain rotors for $430 + Shipping $20.
I will have to buy RSX rear calipers and brakes pads separately. I will buy used RSX rear calipers and cheaper ceramic pads. I don't need track pads that require heating up since my car is a daily driver.
fastbrakes uses honda parts so you can buy RSX brakes pads. If you get Wilwood you have to get Wilwood pads.
Old Jun 10, 2011 | 02:48 PM
kenshin713's Avatar
I just came back from Taiwan. They have the fit there and drive on the left side like the US. anyways, their Fit has rear disc brake.
Old Jul 24, 2011 | 02:23 PM
b15azn's Avatar
haha how you like Taiwan lol....offtopic sorry.
Yes, we do have rear disc brake on fit but is 2nd generation....
Old Jul 30, 2011 | 08:25 PM
dko's Avatar
dko
if your brakes can lock up your tires then there is zero advantage in stopping distance gained by improving your brakes. the weak point of the braking system is the tires. the only thing a BBK will do is allow repeated hard braking with reduced fade, assuming that the kit is well designed. you can increase braking performance by getting better tires, running optimum tire pressure, and to an extent having a better suspension allows better braking on rough ground by keeping the wheels and tires in contact with the road more of the time.
It FITs Me
May 2, 2026 11:52 PM
TaubBaer
Dec 6, 2020 10:51 PM
Steven Hung
30
Apr 17, 2019 04:45 AM
xm8
Nov 14, 2010 12:21 AM
xm8
Sep 9, 2010 12:59 AM
