Ingalls bolts?
Old Dec 13, 2012 | 01:36 PM
Wafulz's Avatar
Question Ingalls bolts?
hey there is anyone running Ingalls camber bolts just wanted to know anyone review on these
81260 - 14mm Fastcam Bolts, Pair - Ingalls Engineering Co., Inc.
Old Dec 13, 2012 | 02:16 PM
feared's Avatar
they're pretty much all the same. eibach, spc, ingalls, etc. same bolts for gd and ge.
used them on my gd. no problems.
got a pair for sale if ur interested.
Old Dec 13, 2012 | 06:36 PM
mkane's Avatar
We use them, top and bottom on a 2012. 2.3 deg -camber
Old Dec 13, 2012 | 07:11 PM
Wafulz's Avatar
thanks mkane do u think im safe with just 1 bolt ?
Old Dec 13, 2012 | 07:21 PM
TPColgett's Avatar
1 is "safer" then 2, but as long as they are correctly installed, adjusted and torqued by an alignment shop, you should be fine.
I run 2, top and bottom. Have run between -1.5 to -3.5. Setting my toe to 0 up front was the biggest improvement though
Old Dec 13, 2012 | 07:22 PM
Wafulz's Avatar
so if i run 1 bolt at -1.2 i will be ok ? sry this camber bolt shit crazy
Old Dec 13, 2012 | 07:28 PM
TPColgett's Avatar
What are you worried about? OK from what happening? Heck, when they aligned my GF's car I think they got close to -1 with just the OEM struts.
If you are worried about tire wear, IE "camber wear" you should really consider adjusting your toe to zero. Toe eats up tires faster than -1.2 of camber will.
It will make the car more responsive, especially at speed. Easier for the wheels to pull or follow grooves on the free way, but nothing too bad if your already awake and paying attention
Old Dec 13, 2012 | 07:34 PM
Wafulz's Avatar
i just got my buddy clubs and getting installed monday
So i should run -1.2 and Toe 0
Old Dec 13, 2012 | 07:42 PM
Wanderer.'s Avatar
^You should run as much camber as the bolt will allow you and 0 toe.
Old Dec 13, 2012 | 07:44 PM
TPColgett's Avatar
+1
I ran -1.5 on my GD for over a year with no noticeable increase in tread wear.
Old Dec 13, 2012 | 07:54 PM
mkane's Avatar
Tire wear seems to be a moot point. Our last auto x was in October and we installed new tires and see zero wear problems @ -2.3 with 0 toe.
tougerunner86
23
Apr 19, 2016 07:16 PM
bluesaint
Aug 14, 2013 11:11 PM
onetwothree
Apr 2, 2013 11:30 PM
flushge8
Hawaii Community
41
Feb 17, 2010 01:25 AM
Spooling
Oct 9, 2008 02:23 PM
