KONI STR.T Orange Shocks
Old Feb 18, 2015 | 06:50 AM
RedShiftChris's Avatar
Check if the shocks are making the squeak noise by squirting oil on the shock piston where it enters the shock body. if that makes it go away, then it's the shock's upper seal. warranty claim... it won't go away for long.
Cheers!
Chris
Old Feb 18, 2015 | 02:34 PM
hspatz's Avatar
Originally Posted by Osubeaver
hspatz,
Is yours still making noise? Installed mine and put about 1k miles on them and on of the rears is making some major squeaking noise at low speeds on bumps. If I stand on the doorsill and rock the car I can recreate the squeak. I'm thinking about taking and off and checking it out, but curious if you had/have the same noise.
Yes, I had same problem. I rocked my car by opening a rear door and pushing where the door meets the roof. I still get an intermittent thumping on one side when I hit moderate bumps, but not the squeaking. Make sure that the rubber grommets or dampers are put in properly. The flatter side must be toward the vehicle mounting surface and that means the bottom one is flat side up and the top one is flat side down. I used grease from a grease gun and spread it all around on those rubber items and between the large washer and the dust shield. All the squeaking went away.
Too bad Koni didn't do the smart thing and include all the hardware, so you do not need to reuse the old stuff. The front Konis have been perfect.
Old Feb 18, 2015 | 03:16 PM
Waiz's Avatar
Avid FitFreak Poster
I have the same noise as you but it's very rare. The quality of the ride after the install is well worth dealing with this very rare issue
Old Apr 26, 2015 | 01:29 AM
Osubeaver's Avatar
Agreed on the improvement in ride quality outweighing any noise.
Got this response from Koni if anyone is interested. The noise on one strut went away on its own, now my passenger side strut it making the noise. Haven't had a chance to try greasing it, but thought I'd put Koni's response.
"Thank you for contacting us here at KONI, and I am sorry to hear you are experiencing some issues with you STR.t damper. In most cases a noise, or squeaking guide seal from a new damper will eliminated itself with use and new friction introduced by the shock cycling over time. Other cases squeaks have be resolved by applying a light coat of lithium grease, or similar lubricant to the shocks rod near the guide seal. If the squeak continues, and no remedies seem to help in eliminating the noise, KONI will replace the shock under warranty. Details on how to file a warranty can be found here http://www.koni-na.com/warranty.cfm ."
Old Apr 26, 2015 | 05:51 PM
Waiz's Avatar
My noise was actually my Mugen rear underspoiler being a tad loose
I removed it and retaped it and no more noise
I'm 2 months into ownership of these shocks and very happy with them!
Old May 18, 2015 | 03:56 PM
n0thing's Avatar
I took it all apart and put Shin Etsu grease on everything. It got rid of most of the squeaking. They sounded HORRIBLE when I bought the car and are a lot better now so I'll just turn the radio up to ignore what's left.
Old May 28, 2015 | 07:48 PM
Regdog77's Avatar
How much did you guys pay for your Koni Orange? Trying to get a feel for what a good price is.
Old May 28, 2015 | 08:17 PM
xxryu139xx's Avatar
Old May 29, 2015 | 01:49 AM
FittinglyFittedFit's Avatar
I paid about $250 from autoanything, free shipping.
Old May 29, 2015 | 08:39 PM
Regdog77's Avatar
Ok great. I paid about that. Thought it was a great deal considering what they normally go for. I am excited to pair it with the sportline springs I have sitting around.
Old May 29, 2015 | 10:07 PM
I agree, and having lifetime warranty is great!
I'm sure you will enjoy these with your new springs, I love how my car drives now after shock/spring upgrade! Good luck and let us know your results!
Old May 30, 2015 | 03:12 AM
  #32
xxryu139xx's Avatar
After reading some more about the Konis on FF, I decided to pick up the removal bump stops/sleeves for the GK. Looks like Jhn got it to fit around the konis no problem, so i'll give it a shot. for 5 bucks each, can't go wrong.
Here's the part number:
52610-T5R-A02
Old May 30, 2015 | 09:31 AM
  #33
jhn's Avatar
jhn
52610-T5R-A02
That part number looks to be the entire shock assembly. Are you looking for the metal sleeves or the elastomer bumpstop itself?
The Koni's include replacement metal sleeves because the OE sleeves are crimped onto the GE shocks. They're not crimped anymore on the GK; they just slide off, so I reused them. Actually, I didn't use any of the included Koni hardware. All of the OE is reusable.
This is how it looks assembled and mounted inside the tower:
Dissassembled. The upper pad that seats up in the tower just slides off. You can see the metal spacer inside. Slide the bumps top/ plastic shield on the Koni first, then the tower assembly which has the washer that stops on the shock shaft seat, bump stop withplastic shield attached, insert into the tower of the car and install the top hat assembly and tighten it down. It took me longer to write this than to do it. Super easy:
These shocks kick-ass!!
Old May 30, 2015 | 09:47 AM
  #34
jhn's Avatar
jhn
This pic you can see them. I know they're not designed for this car but I'm really happy with how they perform.
Old May 30, 2015 | 11:22 AM
  #35
xxryu139xx's Avatar
jhn,
just received an email from bernardi that the part for the sleeve is no longer and must be bought with the whole assembly. boohoo.
so you're saying with the Konis they come with the dust cover/sleeve that was needed to be removed from the oem strut?
Old May 30, 2015 | 11:49 AM
  #36
jhn's Avatar
jhn
Im not certain which parts you're looking for. Koni includes the metal tube spacer, washer, top hat washer and nut. No plastic or rubber parts.
Old May 30, 2015 | 01:17 PM
  #37
xxryu139xx's Avatar
I guess ill find out monday when my shipment comes
Old May 30, 2015 | 10:25 PM
  #38
Mr.Hollow's Avatar
Keep us informed which parts need to be transferred over from the oem assembly onto the koni's.
Thanks!
Old Jun 1, 2015 | 04:57 PM
  #39
Waiz's Avatar
52610-T5R-A02
Why not use your existing sleeves? Mine have no issue whatsoever and I am guessing others who may have an issue are more likely related to how they were installed
Here are mine
Rear
Front
Old Oct 15, 2015 | 09:21 PM
  #40
space egg's Avatar
I think i will pull the trigger on just the rear koni streets.
I''d be keeping the stockies up front.
my springs are 125/lbs (2.3kg) front
and 200/lbs (3.6kg) rear
any thoughts?
