Is a thrust angle alignment needed for the FIT ?
Old Nov 24, 2015 | 09:21 PM
Odie's Avatar
Is the rear axle fixed and not adjustable ? What are the alignment specs for the FIT ? Thanks
Old Nov 25, 2015 | 07:16 PM
dwtaylorpdx's Avatar
I've never found a car that did not benefit in terms of tire wear especially by having a 4 wheel alignment done. And usually you get less road noise.. Even if the rear is not adjustable the alignment rack will try and put the front tires running parallel to the rear rear..
Plots
May 3, 2014 09:57 PM
AutoFit
Sep 12, 2012 07:55 PM
Stacey444
Nov 16, 2011 09:37 AM
theorbo
May 19, 2010 02:07 PM
jimmyparky
Jul 16, 2009 09:59 AM
