GE8 Fit Shoes Picture Thread?
15x6.5 +40 Konig Helium (with hubcentric rings)
205/55/15 Yokohama S-Drive
Tein S-Tech springs
Tiny rubbing in the front if I hit a decent sized bump in a corner. Going to add my camber bolts and see if it fixes it. It's just hitting the fender liner so no biggie.
Tein S-Tech springs
I like your set up and glad you posted these pics.If I go 15's on my GE I will run something like you have.
I'm on Swifts so not even as low as you and I think I could live with mild rubbing.I would love to run 15's with a 205/50 but I don't want to go any lower then the Swifts.
even if I eventually get coilovers I will not be going very low.Let us know how things go once you do the camber bolts.
Thanks zilla glad I could inspire.
205/50 will be a little short but tire selection sure is much broader. If you don't mind the shorter effective final drive ratio and speedo being off a little it's definitely a good tire size. Would work better with a 7" wheel performance wise, but beware of the back spacing difference between 6.5 and 7 if you do. Offset numbers are relative to width and not definitive. Oh I'm referring to rub here.
I just like the bulgy look and wanted to keep the comfort from the sidewalls, keep speedo and mileage accurate, and the tires I wanted were offered in the size, so it made sense. Also filled the wheel wells how I wanted. If you do 205/50 with swifts there will be a bit of wheel gap, but if you don't mind that it'd be all good.
Work mesiter s1
[IMG]http://http://
[/IMG]
Hello there. Im new hir. I gt a 2010 fit. Stock height. Im planning to change my mags. Upgrade to 17inches. Work meister s1. Painting it with black face.
Specs: 17x7.5 et 42,
Planning tires of: 205-45-17. Will it rub? If i have full load and deep turns?
Pls help? Thnk you so much. Mabuhay!!
[/IMG]Hello there. Im new hir. I gt a 2010 fit. Stock height. Im planning to change my mags. Upgrade to 17inches. Work meister s1. Painting it with black face.
[IMG]http://http://
[/IMG]
Thnks. I have stock height. Would i have rubbing issues with a full load or sharp turns? The width is 7.5? Thnks bro
Stock height u shouldn't at all ... When u lower then u shouldn't either but wouldn't hurt to roll the rear fenders
Thnks bro. Will show you some pics when I buy them. Thnks 4 helping out. Just scared of the rubbing issue.
Nice!!!! I'm selling my Megan coils if interested! Got a thread in the forsale section! But going the right way! Keep it up
[/IMG]
[/IMG]
[/IMG]
[/IMG]
