GE8 Fit Shoes Picture Thread?
Old 05-27-2009, 01:06 PM
danielg's Avatar
That is pretty good fitment man. I heart your wheels! It gives me a good baseline for my setups in the future. Thank you very much!!!
Are you planning on running air bags?
Old 05-28-2009, 01:47 AM
515's Avatar
515
515 is offline
glad I could help... Air bags hmm.. probably not.. had bad experience on bags setup..
coilover is better & it's a challenge to drive low on coilover
Old 05-28-2009, 10:31 AM
BakedCookies's Avatar
work-meister-s1-pic-2.jpg?t=1243141058
SOOOOOOOOOOO HOT! Just wish the barrels were gloss white as well.
Old 05-29-2009, 10:36 AM
natepartlan's Avatar
someday some young'un is gonna have to explain to me the visual appeal of stretched tires.
Old 05-29-2009, 10:42 AM
awptickes's Avatar
Same here. I don't get it either. I think it just makes it look like the owner didn't want to buy new tires.
Old 05-29-2009, 11:54 AM
projekz's Avatar
Mine is in my sig!
Old 05-29-2009, 01:15 PM
danielg's Avatar
A stretched tire is used to put wide/low offset wheels on a car. An aggressive set of wheels with a correct tire size will rub the fenders. When people go for the flush or poke type fitment, they need to stretch in order ensure that the car will roll and sit properly when lowered.
Drifters also typically stretch tires to get stiffer sidewalls. However this is really the only case of racers using this, as other than stiffer sidewalls, there is no performance benefit.
As far as safety concerns goes, we've all heard about someone talking about someone who knew somebody that's friends neighbor who's on a forum has some kind of crazy blowout and it was due to the small tire.... I personally know a BUNCH of people who run stretched tires and are doing fine. I have personally daily driven on stretched tires and both the car and myself are fine. There's only 2 thing you need to worry about running stretched tires. 1. Tire wear. If you're stretched to shit, your tire life goes bye bye. Add camber and say hello to new tires every 6 months (unless your -5 or -7, then you can flip your tires). If you're a mild stretch, tire life should be somewhat close to normal. 2. Because the bead of the tire is so far away from the wheel, you are more susceptible to curb rash. I've curbed my wheels going up a steep driveway at too deep an angle. Also, if you're running a stretched tire on a low profile, there's less cushion to protect the wheel from deep potholes etc. I usually have enough time to notice the imperfections in the road and slow down/move. To me, it's not about going fast. It's about going slow and low.
HTH
Old 05-29-2009, 04:37 PM
mholbrook38's Avatar
Enkei NT03+M 7.5 x 17 et 45 Yokohama Parada Spec 2 205/45/17 Nice & Sticky!!
Old 05-30-2009, 12:20 AM
danielg's Avatar
mmmmmmmmmmmmmmmmm NT03 mmmmmmmm
Old 05-30-2009, 11:15 PM
515's Avatar
515
515 is offline
HTH
+1 on this comment. it's all about going slow & low + for show.
u drive to fast then NO body gonna notice ur ride
Old 06-24-2009, 12:48 AM
JDM_DOHC_SiR's Avatar
Talking
Some nice pic's in here... I'll update this thread with some new pic's after the "NEW DROP" pic's are done ...... can you say tucking rim on 18's
  #32
Old 06-25-2009, 05:41 PM
OEMfit's Avatar
My wheels and its for sale NOW!
More info: https://www.fitfreak.net/forums/soca...dunlop-z1.html
  #33
Old 06-26-2009, 12:06 PM
Fallen_Rock's Avatar
I'm gonna hold you to that.
  #34
Old 06-26-2009, 05:38 PM
VTECJunkie's Avatar
Badass fit with SSR Type Fs
SSR Wheels - SSR Type-F
  #35
Old 07-24-2009, 08:31 AM
doughn's Avatar
anybody tried the 215/17/50? for the 09 fit?
i dont like the 40's and 45's ride... tooo hard for me.
  #36
Old 07-30-2009, 08:04 AM
bencho's Avatar
Ok I've read through quite a bit and going to make a semi-informed post. I hope I worded it clearly and the question is not a repeat.
2009 Fit Sport.
I'm deciding between Konig SuperMesh and Feather. I've read through all the combinations but have mixed thoughts. The SuperMesh's only go up to 16" while the Feather's are available up to 17"
So from what I see, there are many differences in rubbing results when you use the same wheel size with different springs and tire sizes. This is logical since each spring lowers by a different amount and tires are fatter or thinner. The closest set up to what I'm looking for was posted by Koi with his Konig Heliums @ 16x7 | +40offset | 205/45 | Swift Sport Springs [I think? He didn't mention] He mentions front rubbing even though the Swift Sports offer the smallest amount of lowering [1.2 Front/1.0 Rear]
I don't know much about the suspension and shocks yet as I'm waiting for an answer in my other thread. I plan to get the Swift Sports and match them to whatever shocks are suggested/best matched for them. I want NO rubbing whatsoever, even with a full car, BUT I want the improved handling with lowering.
I'd like to get 205/45/17 but in some cases that rubs and sometimes it doesn't.
Would going down to 195/50/17 help with the rubbing since the tire width is reduced and thus further away from the wheel well?
I'd settle for 16" if that will prevent rubbing.
So if I plan to get Swift Sports, what will guarantee no rubbing?
In summary, my options are:
SuperMesh 205/45/16
SuperMesh 195/??/16
Feather 205/45/17
Feather 205/45/16
Feather 195/45/16
Feather 195/50/16
Is this correct?
  #37
Old 08-27-2009, 03:34 PM
dsdandaman's Avatar
Originally Posted by 515
new member
here is mine...
Sorry for the pic, taken using camera phone.
then second wheel replica RE30 18x8 +45 added 10mm spacer at front to clear BBK
do these 18x8's rub in any way?
  #38
Old 12-12-2009, 09:02 PM
mk donz's Avatar
just want to share
My BBS RS 16x8 16x9
My gold enkei RPF1 18x8.5
  #39
Old 12-15-2009, 02:42 AM
EK3 Ferio's Avatar
Updated Pic.
Rays 57 Motorsport G07WT 17x7 +43 Winning Blue
Volk Racing CE28 16x7 +42 Magnesium Blue
Volk Racing TE37 15x7 +43 Magnesium Blue
  #40
Old 12-16-2009, 12:49 PM
kkeevviinn's Avatar
iForged Equip 19x8 +38 and 19x8 +21
Quick Reply: GE8 Fit Shoes Picture Thread?
