Wheel spacer help
Old Mar 3, 2010 | 03:27 AM
surfyak's Avatar
Wheel spacer help
I am thinking about installing the ICHIBA V2 BOLT-ON WHEEL SPACERS using my stock 16 inch Sport wheels. Are there recesses in the wheels deep enough for the wheel studs, or am I going to half to cut them to get the spacer to fit?
As far as thickness, what do you think, 10 mm front, 20 mm back?
http://ep.yimg.com/ip/I/yhst-7468432...6_2053_3519941
Old Mar 3, 2010 | 11:29 AM
surfyak's Avatar
Are there recesses in the wheels deep enough for the wheel studs, or am I going to half to cut them to get the spacer to fit?I am referring to recesses on the back of the rim.
I borrowed the image below from another forum, no I am not running 19"
[IMG]http://i4.photobucket.com/albums/y103/luck11/open01.jpg[/IMG]
Old Mar 3, 2010 | 06:33 PM
FITMugen's Avatar
I ran 15mm wheel adapters in the front and 25mm wheel adapters in the back on stock sport wheels. The wheel adapters should fit without any problem.
Old Mar 3, 2010 | 06:38 PM
surfyak's Avatar
thanks FITMugen
Old Mar 3, 2010 | 10:16 PM
jookybanana's Avatar
even with 10mm wheel adpaters, the stock rims cleared the studs
i had 10mm project kics adapters
bpyoung83
Apr 20, 2015 06:16 PM
boomboxbeat
Mar 27, 2011 11:04 PM
ofay
Aug 15, 2007 11:54 AM
CarDemon
Sep 6, 2006 05:59 PM
