Work Wheels
I'm considering the same set up except going with 11R
I know there will be some gap at stock height and even with mild drop
but that's fine with me.I'm still deciding on springs or coils
thanks
+47 all around with 5mm spacers on the rear
no rubbing even with a this huge metal tent in it... and this this is heavy
http://sphotos.xx.fbcdn.net/hphotos-...17054558_n.jpg
in this picture i was lowered on tanabe nf210, i am now lowered on buddy club n+ and i must say the ride is pretty descent
you like the 205-40's? im thinking of going with the 195/45 S-Drives that Evilone recommends...
If you're not going very low, then the 195/45's would be the better choice, since it's closer to the OEM specs.
I'd go with the 205/40's personally. Depending on your drop, the 45's might give you rubbing issues (but again, that depends how low you're going). With where I currently sit on BuddyClub's I'll be making the switch to 205/40's from my 215's to get rid of the rubbing issues I'm having.
how low you think could go with the 195/45/17 with out issues? and since no one even carries this size i might lean towards the 205/40/17
if thats the case, i need to review brands to see which is a better buy and better quality...
Why buy such expensive wheels in such safe fitments? I mean, I know their not going to be CCW expensive, but if you are going to spend so much why not buy something fits at least a little more aggressively...
gd3kamiwanaB
16
Nov 19, 2009 10:41 PM
LowBUDGETs2k
36
Aug 4, 2009 04:28 PM
