2007 STi BBS wheels?
Old Jun 30, 2013 | 08:17 PM
Sticky Tires's Avatar
Hi guys,
Will 2007 STi BBS wheels fit on a 2011 Fit after a 5 lug conversion? Would the bore length need to be changed? Spacers required?
Thanks in advance. Traded in the STi and had the stock wheels leftover and wanted to know if they fit. If not, going to sell them.
Old Jun 30, 2013 | 08:38 PM
Katsumoto's Avatar
They should as long as their 5x114.3.
Maybe not on the bore, but that's easily fixed.
Old Jun 30, 2013 | 08:45 PM
Yes, they're 5x114.3. Thanks for the info. Time to look into hub conversions.
If anyone has more input, please chime in.
Old Jun 30, 2013 | 09:08 PM
After some research, it looks like there's no true 5 lugs (4 disc) conversions?
Old Jun 30, 2013 | 09:19 PM
13fit's Avatar
Go to a junkyard and find some 5 lug hubs from various other hondas, take them to a machinist in your car, and ask him to inspect your fit and see if he can machine the 5lug hubs to fit
Or you can swap in CRZ front knuckles/hubs and entire rear axle
Gain brakes same way
Old Jun 30, 2013 | 09:42 PM
So the CRZ swap would be a direct bolt on with no custom fitting?
Old Jun 30, 2013 | 10:43 PM
Dean's Avatar
CB on a Honda is generally 64.1mm.
Subaru STi wheels off 2007 are 56.1 so you'd have to bore out an additional 8mm on CB for it to fit. The BP's are the same for crz 5lug?
Or get 4lug to 5lug adapters then sort out offset.
Old Jun 30, 2013 | 11:05 PM
Sounds like too much of a hassle to make it work. Plus, not a fan of adapters.
I'll just sell the wheels and stick with the 4 lug.
Thanks for the help guys!
Gingervitisman
Jun 27, 2014 10:53 AM
BlueBoogers
13
Jun 5, 2012 07:49 PM
fg42man
Jul 3, 2011 07:28 PM
aziatiklover
Aug 25, 2006 08:46 PM
divisionerror
May 15, 2006 12:16 PM
