Wheel/Tire Combo for 1" Lift
Old Mar 20, 2018 | 04:29 PM
PolymathPaul's Avatar
Unlike most, I'm going the opposite direction with my 2012 Fit: UP.
Why? I live in the desert southwest, where many hiking spots (and my driveway) are just a little too rough for the little Fit, but alas it's paid off and my loves it (mostly for its color) so we want to give it just a bit more functionality. The purpose of the lift isn't just for ground clearance, it's also to fit slightly taller 25" diameter tires (which I hope don't rub on the front struts).
I plan on using 2011 Insight springs with slightly longer travel shocks. Still trying to find suitable shocks.
The lift should be around 1.25".
I expect this will make the Fit a little bit more tippy, so I'd like to combat that a bit by widening the track some.
I hope to use 185/65R15 (24.5"), 195/65R15 (25") or 185/75R14 (25"). Fairly tall, narrow tires.
I'm wondering if since I'm not lowering the car, and I'm not going with super wide wheels, if I can't go up to a +35 or +30 offset wheel? It looks like 7" wide and +35 is pretty flush with the fender.
Any suggestions?
Old Mar 21, 2018 | 03:20 PM
CommanderSlug's Avatar
I am in the same boat you are ... but in the city ... trying to dodge potholes in my GK.
Stock is 185/60 R15 with the OE steelies. I tried 195/65 R15 and the increase in height is great! I am also using rubber spacers that you shove in the springs:
Amazon Amazon
Old Nov 19, 2018 | 02:50 PM
Davis2001r6's Avatar
Did you ever manage to lift your fit or get larger wheels? I'm curious what the largest that will fit for 15" rims are.
Old Nov 19, 2018 | 03:23 PM
I have not. My original plan was to use the 2nd Gen Insight springs for a 1-1.5" lift, but the inability to adjust rear toe means I probably can't go that drastic on my 2012.
I may just do a 1/2" spacer install as I doubt that'd much impact on rear tire wear.
Old Jul 17, 2021 | 08:05 PM
Kombi's Avatar
Has anyone ever got a good answer for this?
I'm in a rural area, and tired of grounding out on all the freshly gravelled roads, I'm thinking of adding 2" to the tire diameter to get a 1" lift. Hoping to put a set of 205/70R15's on the stock steel wheels. Too much??
2013 Base Model Fit.
Old Jul 18, 2021 | 11:13 AM
I did the Mongol Rally with a 2010 Jazz (Fit). I put rear springs from a Honda Insight on. And front strut spacers off eBay from a Russian place.
https://www.ebay.com/itm/Front-strut...-127632-2357-0
I went with 185/65/15’s. I tried a set of 195’s on and I didn’t like the gearing on the highway with it. 5 gear became useless to maintain speed on even the slightest hill. Too lugging for my liking.
I do know a guy running 205/60/15 on et53 backspaced wheels with no rubbing as well.
Its possible 205/70/15 may fit with a lift, but honestly I think I will drive like shit on the highway and hills.
Old Jul 18, 2021 | 11:22 AM
Dark blue is stock wheels and 185/65/15 tires.
Light blue car is 205/60/15 53 backspacing
Old Sep 27, 2021 | 02:42 PM
Kurse's Avatar
nice!
which model of tires are you guys rolling in gravel road?
Old Sep 27, 2021 | 03:18 PM
Originally Posted by Kurse
nice!
I went cheap but with a higher load rating if I recall.
Toyo NanoEnergy 3 185/65R15 92T XL.
The aren’t gravel tires by any means but did just fine driving to Mongolia and back.
TaubBaer
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Jan 23, 2015 10:34 PM
jdmgirl
Jan 29, 2014 05:19 PM
HEMI-Fit
Car Shows, Events, and Racing
111
Aug 10, 2012 02:24 AM
inxsole
Nov 4, 2009 12:55 PM
HEMI-Fit
Feb 10, 2008 11:55 PM
